Yes the 2 gal Ropax is $88 on amazon.   I am going to shop around for tat...maybe Ebay.   I need a tool rack. I take my Dewalt pole saw /trimmer back to clear paths in woods so I can ride back to squirrel hunt. There is a lot of Multi Flora Rose that I am eradicating.   I have to tie the pole saw on the front rack.
I cut a Rack I had bought down to about  40 inches. But the new reciever was to short and the rack would rub the tires ...Dirty Damn
being frustrated i did not think they make receiver extension!  However I think It would be wiser to keep the pole saw up on the front rack with a tool holder.
The pole saw is too big for the rear rack  I cut the original rack down to this size.  It will be handy on the Foreman for other stuff.  But a tool rack on the front would be better.
I would suggest a little welding project.  Build a hitch extension similar to a bike rack..  Come out from the receiver,  up to  a desired height (  I  would say  just above rear tire height)  and attach a receiver there..  You  could mount your tool rack there.. It  would keep  it   high so it doesn't hit the ground when  negotiating  the dips and humps in a trail . Mounted  at receiver height extends the rack so  far behind the rear wheels it would drag on going through  or over any but the smallest dips and bumps.
Yes you are right.  Damn , I never thought of that.  It's rough back there going over rotten logs and rocks.    I have some 1 1/2 Unistrut that I could use for the Rack.  My wire welding looks good after I grind the bubble gum down...LOL
I wonder if I should stabilize the rack with a soft attachment to the rear of Foreman's rear rack?
I like the pumpkin
I would use  2"  square tubing to  come out from the receiver and for the upright to  the receiver at top  for the rack.  An angle brace from the horizontal  to the upright and  on to to the  receiver would be good too.. You  could use soft attachment at top to  help stabilize the rack  side movement.
i have 7 ft. of  some 1020 dom roll cage 1 3/4 inch pipe left over .   i think the unistrut on the horizontal rack member would allow easy adjusting of tool brackets.   i have some 2 inch box tubing for the reciever.
i'll send pictures of my Rack...
I think I will do both; the hitch extension with a 6 in lift on the rack mounting as well as a tool rack up high at the level of the rear Foreman Rack.
I  like to haul stuff from the car/truck to the storage shed.  The lower rack would drag.
Sounds like a good plan.  With the rack extending so far behind the rear wheels even with the 6" lift  it'll likely  only be good   on relatively flat ground. though
Yes, You're right... I'll need to have a 6 " lift on My rack.  However, I want the tool rack up higher as when I am driving through the woods there are some extreme terrain changes.  You know like where wheel ruts are 12 " deep.
Tool rack  level  can be at  top of tire height  up to  level of the original Foreman rack. The higher the tool rack, the more torque  is exerted on the assembly from  sideways rocking  movement as you're traveling.
6 hours ago, jen said:
Yes  can I dampen that lateral movement  by a soft attach to foeman's Rack?
Yes you can do that  .It's  just the longer the arm is from the receiver  the  more torque has to be overcome.Unless there is a need to  have the rack  up  level with the rear rack  I think the  shorter  height is better, but that  is  just personal preference.
Ok I will only make the tool rack 2 inch tube and hole so that the rack is beyond tires by 2 inches of clearance.    I plan on making the rack  44 inches wide (pole saw parts are 43 inches ).   I think Dynamic loading as the rack bounces back can be reduced if I tether the tool rack to the Foreman rack.
But it will be Saturday before I can tack (Bubble Gum) something together and post a picture.     I bought some tool brackets for front Forman rack.  I like to carry a pitch fork and my double bladed axe also.
Thanks for all the great ideas.
Ok i tach'd together this ...Could not find my unistrut so used this stop sign pole...The thing weighed  28 lbs...OMG.
I decided to use just a basket to use for my log chain, etc and put the pole saw on the front rack.
The hitch by itself only weighs 9  lbs.  I have a plastic basket that is lighter than this antique Milk Basket  Who said girls change their minds!image.thumb.jpeg.1499e0629337b84246da19a0710aa62d.jpeg
The receiver part is 1/4 in X 2 " box tubing.   The vertical piece is thin 2 inch tubing from maybe and old bike rack or somthing.  I welded and also bolted  w 3/8th bolts  an angle strap.  Hope the hitch does not drag the ground back in the woods when it is on the Forman.
I am looking at a fire extinguisher for the ATV, The SXS and my Sandrail.  I guess an ABC is best. however the mounting must be secure and easily accessible .   I think I will mount the one on the sandrail so it is pointing at the motor.   Some manufacturers make "non corrosive" ABC fire extinguishers.  For the sand rail I would want that.  My gas tank is just behind my seat as seen in picture.image.thumb.jpeg.2df0dcfc3ac6145c84fd80214d1f205f.jpeg
There is one  that is aluminum and another that is injection molded nylon...I could use it as a firewall on the Sandrail  with a fir extinguisher  .
fuel pump is below tank.  The firewall would be between the fuel pump and the motor. So I can access the SO (Shut off  ) valve and check for any leaks at fuel pump.   VW motor is magnesium alloy ..burns hot!  dont use water!
That is obvious!  I should have thought of that.  I could attach so the release would be just above my head.  When sitting in harness with straps across my shoulder I cannot reach around to the side but I can reach up.
      Best ATV for Older Riders
      Polaris Sportsman 570 EPS
      Best Reliable ATV for Seniors
      Honda FourTrax Rancher EPS
      Best Features
      Best Premium Comfort ATV
      Can-Am Outlander MAX
      Standout Comfort Features
      Best ATV for Easy Handling
      Suzuki KingQuad 500AXi
      Why Older Riders Like It
      Yamaha Grizzly 700 EPS
      Best Features
      Arctic Cat Alterra 600 TRV
      Key Advantages
      Electric Power Steering (EPS)
      Automatic Transmission
      Lower Seat Height
      Two-Up Models
      Hand Warmers and Heated Grips
      Adjustable Suspension
      Buying Too Much Power
      Ignoring EPS
      Choosing Aggressive Tires
      For most mature riders:
      Final Thoughts
    • By Frank Angerano
    • By sunn
      I have an older 2000 Honda 450 ES which has been a tremendous workhorse since owning it new.  I'm now looking to update neglected maintenance on the machine, looking for advice initially on brake work?
