2002 Xpedition 325 start relay/solenoid
By tds7
Do any have any experience replacing 2001 Big Bear 400 Front Differential Input Shaft bearing and seal. Getting ready to buy one but the seal and bearing are bad. Any help would be appreciated.
By Kawiherder
It starts and runs Ok but after a while the temp gage lights up and the fan fails to start. Any suggestions on where to start looking would be helpful. Thanks
By Matman
Been working on this teardown for a while. Special tools are needed in a few key areas such as Flywheel puller, Crankshaft 52mm wrench, wet clutch puller, etc.
I'm trying to get the wet clutch off now, and a few videos out there show it sliding right off.
Mine isn't that easy.
I measured the clutch's female threads and determined the puller spec needs to be 37mm x 1.5 LH Male.
Anyone come across identical pullers from another mfg?
The Suzuki tool is tough to track down and expensive for basically a slide hammer-type puller.
Just need to figure out anther way to remove the wet clutch without applying too much pressure on the clutch plates to bend/break the plates or base. All thoughts are welcome to homemade tools. After this I need to cut out my own 52mm end wrench for the opposite side of the crank!
By tjakes680
So I recently cleaned my carb on my 1986 Quadrunner 230GE and had to replace my fuel pump and now it seems im getting to much air and I can not use carb to adjust it I believe its coming in from either my air box or one of the air ducts or possibly the clear air container that is under front of quad that runs into the air filter bag but im not sure. Has anyone have any experience with this happening quad will idle super high and nothing can lower it except blocking off a air duct that leads to main air box i also have to check again for any cracks or leaks in air lines and box and ducts any advice will help im stumped ! What else can cause to much air coming in ? Could it be a leak from engine or top end ?
By bigboy123
When running for a while the rancher will shut off without the fan turning on. We then took it to dealer where it was started and warmed up. The fan came on at the dealer so they then replaced the fuel filter and fuel pump. We got it back and ran good for a few days with the fan coming on when needed. Now its back to shutting off before the fan ever comes on. It seems like the time the fan should come on the bike shuts off. It will start after letting it sit for a few minutes. Any ideas of the problem?
