Mornin Boys, We all don't use the stock oil filters, so here is something to remember,
info from Mobile One
Question:
Reason for Check Valves in Engine Oil Filters
What is the function of a check valve in engine oil filter?
-- Shafeeq Bandagi, Bloomfield Hills, MI
Answer:
The check valve function is used to prevent dry starts that could occur if the filter was allowed to drain dry during standing. It also serves to ensure that oil is always present in the filter, especially when the vehicle is started.
I use the Purolator PL14610 oil filter, not the P14610. that one don't have the check valve in it. I also use the Mobile One 0-40 oil and any good synthetic tranny fluid for the tranny. The only thing I use from Polaris it the front Hilliard tranny fluid, There are a few good oil filters you can use, just make DARN sure it has the check valve in it. Our oil filters are on the side, not the bottom,,
Edited by hobbles
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
    • By kevinohio
    • By LCP92
    • By digrig
      Hey everyone,
