redneck9788 Posted March 14, 2009 Share #1 Posted March 14, 2009 i want to paint my plastics but i dont know how it will hold up to the flex of the plastic. if anyone has input on this issue let me know Quote Link to comment Share on other sites More sharing options...
Sparrows Posted March 14, 2009 Share #2 Posted March 14, 2009 Use Krylon paint, it's the best. it will still chip tho. use about 10 coats and you might be "ok" for a bit. Quote Link to comment Share on other sites More sharing options...
quadmaniac Posted March 14, 2009 Share #3 Posted March 14, 2009 You're going to need a paint that embeds itself into the plastic. Those are specialty paints, and won't come cheap as they need to be flexible. Might want to call a couple of auto body shops, they paint plastic. Quote Link to comment Share on other sites More sharing options...
Irideyamahaandhonda Posted March 27, 2009 Share #4 Posted March 27, 2009 I'm pretty sure you can get plastic paint at Home Depot for a descent price. My buddy just used some army green he had laying around on his ATC its been holding up nicely and if it does scratch or chip all you gotta do is keep a extra can handy This is his spray painted ATC Quote Link to comment Share on other sites More sharing options...
Guest michealwaiting Posted April 23, 2009 Share #5 Posted April 23, 2009 I just painted my wifes 400EX and it only cost me about 40 bucks .You need a good prep paint like a primer but NOT , one brand is bulldog. Then about 3 coats of plastic paint and your good. New here but I am trying to get pics to size. Also prep is important clean then wet sand about 400 grit. Quote Link to comment Share on other sites More sharing options...
spazzzzz Posted May 27, 2009 Share #6 Posted May 27, 2009 I work in autobody shop and when painting plastic bumper they put in the paint what is call flex agent it helps when you put the bumper back on the car and to help when it hot outside with the plastic expand and contract but if your painting plastic here some things to keep in mind just how rigid are the parts if there is no damage to them and the parts are color impregnate which means if it was cracked the color is same on inside as the outside like i said before no damage just wash with soap water and wet sand with 600 no primer will be need just sealer if you repair the parts like plastic weld our bodyfiller that is for plastic parts you will need primer now keep in mind the paint im talking about is use in autocollision shop you can buy them but their not cheap and if you dont have a gun well you can rack up a nice bill if your only going to use one time but you can get the samething from spray can use same step i talked about before good luck Quote Link to comment Share on other sites More sharing options...
spartanracing43 Posted June 11, 2009 Share #7 Posted June 11, 2009 Here is a pic of my 2006 YFZ 450 I used Krylon Fusion Spray Paint, its about $6 a can, i used 3 to do my gas tank cover and front plastics. It holds up nicely, its been 6 months and 5 weekends to the dunes and they still look good with only a couple chips from hard riding, but all you have to do is mask off where the chips are and give it a little spray and you would never know. Its a cheap way to change the color of the plastics. Before i sprayed i cleaned the plastics real well, sanded with 400 grit paper and then ceaned them with rubbing alcohol. I'll see if i can get these pictures to post it might take a couple tries. Quote Link to comment Share on other sites More sharing options...
spartanracing43 Posted June 11, 2009 Share #8 Posted June 11, 2009 Quote Link to comment Share on other sites More sharing options...
spartanracing43 Posted June 11, 2009 Share #9 Posted June 11, 2009 Quote Link to comment Share on other sites More sharing options...
outlander560 Posted June 11, 2009 Share #10 Posted June 11, 2009 those plastics look great nice job:yes:..how many coats did u put on them?? Quote Link to comment Share on other sites More sharing options...
Sc0tt Posted June 11, 2009 Share #11 Posted June 11, 2009 Looks good that is about what I did with my Suzuki LT250R. I used the yellow and it came out pretty good I think. We are going to try and do my son's Blaster next I believe. It will be black. I am going to show him your pics. Quote Link to comment Share on other sites More sharing options...
spartanracing43 Posted June 11, 2009 Share #12 Posted June 11, 2009 I put about 3 coats on them , The First coat i went real light to get the feel for it, when using this plastic paint its better to do lighter coats, if you put it on real heavy it is more likely to chip, so the more lighter coats the better but on about my 3rd coat everything was covered and looked good, i painted over yellow plastics so you can see it goes on nicely. Quote Link to comment Share on other sites More sharing options...
wheeler0801 Posted June 11, 2009 Share #13 Posted June 11, 2009 wow. that looks pretttttty sweet. you'll have to let me know how it works out in the woods Quote Link to comment Share on other sites More sharing options...
Snipe Posted June 26, 2009 Share #14 Posted June 26, 2009 I have heard that that the krylon dont like gas causes it to come right off and so do decal sticker. Quote Link to comment Share on other sites More sharing options...
spartanracing43 Posted August 21, 2009 Share #15 Posted August 21, 2009 Ya gas is not good for the plastics, around my gas tank cover it is starting to chip but i just take it off and give it a quick spray and its good to go. Quote Link to comment Share on other sites More sharing options...
shadow Posted January 22, 2010 Share #16 Posted January 22, 2010 I do paint and body work also airbrushing and when you go to paint plastics you not only have to prep your surface good you have to add a flex agent into your paint or you will have chipping later down the road Quote Link to comment Share on other sites More sharing options...
Smoothbassman Posted January 25, 2010 Share #17 Posted January 25, 2010 Those look great! Quote Link to comment Share on other sites More sharing options...
Foolio Posted January 25, 2010 Share #18 Posted January 25, 2010 (edited) YEA THOSE PLASTICS DO LOOK GOOD...I JUST USED KRYLON PLASTIC PAINT FOR MY FRONT GRILL AND GAS TANK COVER AND CAME OUT GREAT. CANT TELL ITS BEEN PAINTED!!!!!!!!http://i84.photobucket.com/albums/k16/indiopdw507/IMG_1704.jpg[/img]"]http:// Edited January 25, 2010 by Foolio Quote Link to comment Share on other sites More sharing options...
dave2 Posted January 28, 2010 Share #19 Posted January 28, 2010 I just pressure washed everything and got some Krylon Fusion camo paint. Done OK for my purposes. Dave Quote Link to comment Share on other sites More sharing options...
lasxgames Posted February 23, 2010 Share #20 Posted February 23, 2010 here is another link for painting DIY: How To Paint ATV and Dirt Bike Plastic - Yamaha Blaster Forum Quote Link to comment Share on other sites More sharing options...
rcrawford1110 Posted April 2, 2010 Share #21 Posted April 2, 2010 i want to paint my plastics but i dont know how it will hold up to the flex of the plastic. if anyone has input on this issue let me know Tried it on my old trail blazer and its crap. check out mine at atvwheelin.com its in the sisters ride the camo one. Quote Link to comment Share on other sites More sharing options...
mywifeknowseverythin Posted April 10, 2010 Share #22 Posted April 10, 2010 THREAD BUMP...... Quote Link to comment Share on other sites More sharing options...
Guest Auyeah Posted April 15, 2010 Share #23 Posted April 15, 2010 I have been having problems painting plastic panels for years. Some of the suggestions were:sand back with 400 / 600 grit to get rough surface, then wipe down with degreaser, then with industrial thinners, use a plastic primer, mix a flexing agent into the paint, use two pack epoxy paint. guess what; the paint still came off. Polaris and Honda only import "go fast"red into Australia. When you are out prospecting / gold detecting you want to keep a fairly low profile. My latest quad (500 Sportsman twin seat) I just took the panels into an automotive repair shop;underneath black and outside camo. Still chips but I can just hit it with black or kharki spray paint and it doesn't look out of place. Quote Link to comment Share on other sites More sharing options...
Guest Auyeah Posted April 15, 2010 Share #24 Posted April 15, 2010 file:///C:/Users/Ron/Pictures/2010-04-1file:///C:/Users/Ron/Pictures/2010-04-15/001.JPG5/003.JPG Quote Link to comment Share on other sites More sharing options...
