1993 Kawasaki Bayou 400 stall and wont start
have a 93 kawasaki buyou 400 it will run fine most times but some times you will be going and it will stall and wont start but if you let it sit for a little bit it will start and run fine but some times when you start it it wont rev up all the way if you try to it will bog then back fire
Sounds like you are running out of fuel in the bowl of the carb. I would suggest taking the carb apart and looking at the float movement. Make sure that the pivot is not corroded.
* Changed your thread title to folllow forum announcement guidelines
I don't know, my 1992 bayou 220 doesn't do that but if i'm going real fast in third gear to get up to speed and then let off the gas a little bit, not all the way, just a little it will start sputtering out so i have to either slowly climb up to the speed I want and leave it there or get up real high and then back off all the way and then get back into the throttle a little to find the speed I want. Also does anyone know how to adjust the cluth on this thing?
    • By Its-always-something
    • By Drillbit
      Hey all,
      Thanks!
    • By kantrud97
      Thank you in advance
    • By DarkRider
