By Mreoiwerk
Hey, I'm thinking of upgrading my stock sport glide seat with memory foam as a bit of a project. I've seen how some guys use the heavy-duty padding inside the water repellent UTV seat cover fit Polaris Ranger XP 1000 crew for their UTV projects and wanted to try something similar for my bike.
Has anyone done a DIY foam upgrade and have any tips? What sort of foam density would people recommend, and how easy is it to remove and refit the factory seat cover over the new padding? Any advice gratefully received!
By quadcrazy
QUADCRAZY NEEDS YOU!
By TomJulio
I recently noticed my Fourtrax 2WD has 4WD wheels installed on the front. The back spacing is significantly different than 2WD wheels and they are almost touching the strut springs and the tires actually do touch the springs.. So far, no luck locating 2WD wheels to correct this issue.
By Olchap
Hi, I am new to this forum I am currently working on my 1989 Yamaha front end. The cv axles were bad so I changed them on both sides with all new wheel bearings. Now I'm looking at the front brakes and the 2 cylinders for the brake shoes on both sides do not work at all. I am also new at working on brakes so its a mystery to me what needs to be done to fix the cylinders. Can somebody please help me with these brake issues? See the image below.
Thank you,
Olchap
