Here is my photo
Flipped it doing about 40 mph across a field. I was bet i couldnt do a wheelie across the entire field(approx 500 yds) flipped it after about 300yds into the wheelie. it bounced about 12ft high and landed on the front left side. the entire left front side is crushed. a-arms both front suspension, front left and rear left rim are bent, steering stem and handle bars are wack, tie rods bent...
      QUADCRAZY NEEDS YOU!
    • By middlebrookgt
    • By PupATV
      -PupATV
    • By bhristianzx12
