  • 3 years later...
need help got 2008 700 4x4 two problems 1 the dash keeps flashing volts put in a new battery still got the problem and 2 the steering when i take off it pulls hard to the left can any bodytell me what might be the problem with these problems
thanks
i have read that if you disconnect the multipin to the pod display, clean it, and dielectric grease it, that may solve it.
if you can raise the rear of the bike, rotate the wheels separately, if you dont have resistance on the left one, you might have an axle/cv joint problem ...
hopefully an A/C guy will jump in ...
you need to check the connector from your stator. they are very prone to failure! the connector melts and causes a short. this connector is of poor design. as for the pulling to the side your caliper may be seizing or a very bad wheel bearing. i dont know the history of your machine so its hard to tell
  • Ajmboy unpinned this topic
    • By Atomusthenes
    • By Tim Keiper
    • By RussB
      Flywheel puller. Does anyone have the size as the part #529 036 049 is non existent
    • By neilroy87
