We are running a test on the log-in of members here and could use some feedback.
Please answer the following questions:
What internet browser do you use? What version?
When you close the browser window, then revisit this site, are you logged in or out?
Are you able to click on the "LIVE CHAT" at the top of the page? Does it open for you?
Any log-in problems?
Thank you.
I use either IE 6.5 or 7 and I have had problems logging on. I put in my pw and it tells me it is incorrect. I have had to reset it twice. It doesn't leave me logging in when I leave but I don't have it save my pw or username so I don't know if it works for others or not. The Live Chat opens when I click it.
Scott
Guest Fox300exchic
IE 6.0
It use to log me out everytime but now it keeps me logged in which I like.
When I click it, it says page not found.
Nope
Also, it depends on how high your security is se within your browser or your security suite. If it's high, it may clear your cache/cookies before you revisit the site.
Guest Fox300exchic
The chat is working for me now. Thats pretty cool! thumbup
The Live Chat thingy doesnt work for me....Says page cannot be foundangry
I dont know anything about my Puter so I cannot answer the Tech Questions....
I think it loggs me in when I come in.....blink I never go to my page or anything I just come to the fourms.....
Also,,,,When you do that Video page.....What is the File Size going to be???? I hope its more than 100mg....Everything off my Helmet Cam is in the GB's....:P biggrin
I got into live chat just fine, and I am logged in when I leave and come back unless I specifically log out... Oh, I am useing I.E., but I don't know which version, sorry.
The maximum filesize of a video clip that can be uploaded from your pc is 100MB, which is pretty large.
If you have a video that is larger, you can upload it to youtube and then to QUADCRAZY, as they will resize it I believe.
Also, you can adjust your video setting most likely on the camera for file output. Less Quality, Less size.
The LIVE CHAT will only work if you are logged into the rest of the site. Try logging in from the main page instead of the forum page and see if it works.
Thank you.
Explorer, but not the latest version.
logged in when I return.
Dont have a mic, never tried live chat.
No log in problems.
Only found this site this morning and so far so good.
John in Vegas
No log in problems.
John in Vegas
Thanks for the feedback!
  • 7 months later...
I use IE, logs in OK, chat does not accept my password. I always log out so I always log in. did I miss anything?
Chat doesn't work? I'll have to check it out...
I am always logged in and havent had any problems. I havent tried any of the chat stuff so I dont know about that. I still use dial up, yeah I know, but the only problem I have is with watching videos, but figure it is the dial up that causes it. Otherwise good to go.
Thanks for the feedback.
  • Admin unpinned this topic
  • Admin locked this topic
    • By PupATV
      Hey guys! I am new here to the forum and need some help getting my Polaris 325 Magnum 2001 Running.....So I got it for free and it has never run quite right...I put a aftermarket carb on it last year and it was running fine but it only went like 20 maybe 25mph max......But then the needle and seat sealed leaked within a yeah and it flooded it REALLY bad so I changed the oil because it was full of gas. So then I put a genuine Polaris carb on it and I have it set to all the factory specs, but it was still not running right....So I replaced the ignition coil and the spark plug and that solved one of the problems I had (It would bog down and stop running when i would go up a hill) But it still didn't have that much "Punch" to it like my Kawasaki Prairie 300 ans Suzuki Kingkuad 300.....So I replaced the CDI but it's still not running right! It's acting like it rich kinda....So it runs mostly okayish when I have the airfilter on but the top of the airbox off but as soon as I put the airbox lid on it like REALLY bogs down and wants to stall really bad. I have the carb at the factory specs and it has a pretty new fuel pump so I have no ideas whats going wrong! It still nly has a top speed of only about 30-35mph and it sounds like it's choking the whole time! Thank you for sticking to the end, and I hope you guys can help me!
      -PupATV
    • By bhristianzx12
      I have acquired a free 92 Polaris 350L 4X4. Ive replaced carburetor from ebay, replaced spark plug, im trying to pull start but sounds like it doesnt want to fire. Spark is a bright orange spark (checked with spark plug tester), replaced plug, pre mixed gas from an external gravity feed tank. Compression test good. Anyone got any recommendations for me?
    • By jhamrick75
    • By Otter9099
      I am new to the area and looking for some areas to ride and explore by atv. Does anyone recomend any trails?
    • By jmeier1981
      Ok guys Ive got a few more for ya.
      TIRES:
      Ive thought about getting new rubber for the wheeler it has some half worn down 25" Kenda executioners on it and Id like to get something that maybe rides a little better and does as good or better in the mud if thats an option. Any tire model suggestions? Also I would like to go to a 27" or mayb e even a 28" are there any disadvantages to doing this would I have to change anything on the wheeler to make up for the larger tires? Ive had a couple people tell me that they would be hard on the clutch.
      WHEELS:
      Ive seen some really nice looking aluminums but not sure they are tough enough to handle trail riding...Are they??? If so what would you reccommend, id like a little off set to give it a slightly wider stance and better stability but a buddy has a set of ITP wheels and the rear is offset a lot compared to the frnt and it looks great but hes constantly getting the back wheels hung up on trails
      SNORKEL:
      I see that the airbox on the brute is where a normal wheelers gas cap would be, so that being said am I good to go with water as long as it doesnt go over that point os is it not sealed up to the box? Also how about the belt and it staying dry, do I need to do anything to ensure that it doesnt get soaked and leave me stranded.
      Oh by the way I love this thing the more I ride it the more Im glad I went with the powerhouse, Ive run with a couple polaris 500s 700s a grizzly 660, and 700 and a couple rincon 680s that were built and they cant touch my stock 750, although she likes her gas thats for sure i got about 50miles and Im needing a refill
