Hi everyone, I'm new here obviously, I'm looking for info on this bike, tried this question on another forum and didn't get much response. Any input is appreciated. TIA!
Hey all, I just bought a 1993 350 4X4. It's in good shape and appears to have been fairly well taken care of. I've been going through it servicing and inspecting it. The owners manual says to check the counter balance oil, and to top it off with 10/30. Only the manual just shows the drain plug and not the fill plug.
I took a picture of what I believe is the fill, in the red circle about the pull start, but I wanted to confirm. I know the plug to the left is the transmission fluid fill and it's full, but the plug on the right in the circle is dry.
Also, just what is the counter balance, what does it do?
TIA!
the fill is on the right side right above the drain plug over to the left right behind the front chain. right is the bikes right as if your the bike. hope that helps.. it is not the easiest to get to.
Thanks! I think I see the plug you're talking about, it does look like fun to get to.
So any guesses if I did any harm by filling my flywheel housing with oil? :no: I drained it without starting it, but I imagine there's electrical in there....
:confused:
after you fill the couter balance se if ita start. (use a small funnel to fill, pour till its full and then clean up the mess after. I used a lot of kitty litter by the time i was done draining and refilling.... as far as damage to anything in the recoil, you'll have to ask some one else.. good luck...
The recoil starter is on the opposite side from the stator, the only thing in there is the recoil starter, the main reason you don't want oil in there is that dirt, dust and stuff will get caked in there. I would take the cover off and give it a good cleaning. To answer your earlier question, "what does the counterballancer do?" It cancels out the vibrations caused by the crankshaft. It is a weighted object that moves opposite of the crank, when the crank weight is up, the ballancer weight is down, and they move in opposite directions.
Thanks DD, but it looks like I got the oddball engine as per my usual luck. On this one the recoil is on the same side of the motor as the flywheel and stator so I did soak my stator in oil. I pulled the housing, cleaned it and then doused the flywheel and hopefully all of the stator with electrical cleaner. I say hopefully as I didn't pull the flywheel since I don't have the puller, but I turned the flywheel in complete rotations while spraying the stator coils through the access hole in the flywheel. I did this several times and then sprayed all around behind the flywheel as well. There really shouldn't be any oil in there now.
The good news, I did find the proper counterbalance fill hole. Checked it and it was good.
Thanks again!
I doubt you have an oddball motor, I was just wrong. I looked at a schematic for your motor and I must have just confused myself. Looking at it again, the drive system bolts to the other side, so it makes more sense that the stator and recoil starter would be together on the side opposite the drive output. My mistake. Let us know how it works out and if it runs ok for you.
Okay, that's good to hear. It would have been just my luck to have the odd one, I usually seem to always buy the first year they did X, the year they changed Y to Z, the one year they got parts from ABC, etc, etc.
I'm still waiting for parts. I have the recoil, casing, and everything on the r/s of the engine back together. It was a good runner when I bought it, but the overflow tank had a hole in it, the fuel tank petcock leaked, the belt is missing a chunk, and a few other minor things needed replacing. I ordered parts from Cheap Cycle Parts, but they are taking a real long time to ship them. I may have to cancel the order and go elsewhere.
As soon as I get these parts I'll have it back together.
Parts finally arrived yesterday, so I worked on it for a while last evening. I still have some reassembly to do, but I did get far enough to start it up and let it run a bit. Sounds fine, looks like I got though my snafu without any issues.
I'm going to try to finish reassembly this afternoon.
I got it all back together, drove it around a bit. Seemed to be running rich, pulled the carb, and yep, there's standing gas in the intake. Ordered a carb kit.
I'll be done eventually. Really. :skeptic:
Standing gas in the intake means either your float is just stuck, or the float stopper is not seating properly. Either situation will allow too much fuel to enter the float bowl and while the quad is not running, fuel will come right up into the carb throat and settle in the intake. Did you notice any fuel flowing out of the overflow tube? If not, the overflow tube may be clogged too, just something to double check.
Thanks guys. I'm still having some carb issues, I think. I checked the floats, no damage or fuel retention. Replaced the needle and seat. Cleaned everything. Someone had worked on this carb previously and didn't reinstall the spring for the pilot screw so they had it screwed all the way in so it wouldn't walk out. (I could back it out and watch it unscrew itself with engine vibrations.)
I thought that would be the problem, but after reassembly it ran pretty much the same. It was running so rich my eyes were burning while tinkering on it. I adjusted the idle and pilot (air/fuel) to the point where it's not as bad, but it surges at low speed and get a mild backfire on occasion. Throttle response seems a bit sluggish too. Don't see any fuel coming out of the overflow. Kind of stumped at this point, this carb is pretty basic and the kit came with new gasket, o rings, jet needle and both jets, and the piston and springs for the enricher/choke system. Float level is dead on, and cable adjustment seems fine.
Any ideas??
check your choke cable adjustment. if it is to tight( no end movement in the relaxed or no choke position) then it holds the choke piston off the seat slightly. if it is to loose it alows the choke piston to float around a bit not sealing proberly. it should be set so the slack in the sleeve is just about gone. if you are back firing you need to up you idle air screw until there is no sluggish action from reving it up in neutral. i would try these ideas befor you test other avenues.
your friendly neighbourhood mechanic
I agree with gearhead on the choke thing, you need to make sure it is properly adjusted. The pilot air screw adjustment is also a good idea, if you turn it in, the adjusment will be richer, turning it out will allow more air to enter the circiut, thus making it leaner. Like gearhead said, with a properly adjusted air screw, there will be no hesitation when hitting the throttle off idle.
    • By mehim
    • By logray
      Hi all,
    • By LMI
