2003 Kodiak Air Filter Box Replacement / Modifications
By wilmpie
hi everybody
I have a kymco mxu 250 automatic from 2006 250 cc that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
thanx in advance
By harryjr
By jordan_ATV
By Kurt Reiser
My quad will not run with the airbox hooked up Will not go past quarter throttle as soon as you unhook the tube at the back of the carburetor it runs great does anybody have any ideas what it could be I have a bad fuel pump one on the way can that cause the quad to run like that
