2002 arctic cat 500 auto won't go forward or reverse
sprad22
Agreed, if the belt sheaves are grabbing and moving the belt properly, then the next possible problem is definately the drive clutch. I would tear down to the clutch and check the clutch shoe and the small one way clutch that is between the clutch housing and clutch shoe. Make sure all moving parts are moving freely and check for excessive wear on any clutch components. One question, have you tried putting the machine into 4wd and seeing of the front drive system will move the quad?
  • 8 years later...
    • By Spritee1
      not sure where to look next
    • By ethie
      Hi All
      not sure where to start
    • By rgeiser
    • By Its-always-something
    • By kiriyaaoi
