Okay so I put a video up on youtube for audio and visual refferences. I seem to be having some issues with the fuel delivery now. I took my stock airbox off and i am running straight UNI Filters and a 147.5 main jet and the e-clip on my mid throttle pin is all the way down on the 5 notch, making the needle as high as it possibly can go. It seems that no matter what I do the thing runs rough in low to mid throttle, but wide open and idle it runs fine. refer to video. I have a 145 main jet a 150 main jet and a 152.5 main jet. I am at a 1130 feet elevation, no airbox, in the video my quad is currently set up with a 147.5 jet, and e clip all the way down on the pin making it the highest it can go. it sounds VERY throaty and feels like it misses, but I think it might be something else. Thats about the best I can describe it in words, the rest will have to be done by listening to it. Here is the link [ame=http://www.youtube.com/watch?v=dRsan-PPgGE]YouTube - Yamaha Warrior Problems[/ame]
If you have any suggestions, or know what settings I should be running on my carburetor let me know, I want to take it out riding, now that it is running, and now that the tempurature is below 100 degrees consistently!
Before I was having issues with the stator and the clutch (got those fixed). Now its the fuel mixture/delivery.
Well after taking the stock airbox off and running a straight UNI filter, i would hope that the quad is getting to much air, thats why I stepped up the main jet from a 145 to a 147.5. The mid throttle pin settings and the main jet settings are the only thing Im having problems with. I was hoping someone might know the settings for both of these on ANY YFM350 motor. Whether it be a Raptor or a Warrior. If someone has run into this and figured out the solution, please let me know.
I think you may have the clip moved too far down, I would start with it in either the stock position or maybe 1 down from stock. Since you are at a relatively high elevation and in a warm climate, there is less oxygen in the air, so you shouldn't need to be too far off of the stock, sea level settings. I would start by raising the needle clip back up and then maybe make an adjustment to the pilot screw. One think at a time though. The pilot circuit will affect things from idle to about 1/4 throttle, the clip position can start having an effect as early as 1/8 throttle and will continue to have an effect up until 3/4 throttle, but it will affect things sooner, when the needle is set higher. Don't forget to check your plug, that is your best way of checking how well you quad's jetting is set.
    • By HeWasRidinDirty
      I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
    • By jeffrocdx
    • By mikeexplorer
    • By Kurt Reiser
      My quad will not run with the airbox hooked up  Will not go past quarter throttle as soon as you unhook the tube at the back of the carburetor it runs great  does anybody have any ideas what it could be I have a bad fuel pump one on the way can that cause the quad to run like that
    • By alexwv1863
      I'm currently working on an 04 Suzuki Eiger 400 and ran into some issues. Main issue being it's really hard to start. Once I get it started, it runs bad. Sounds like it's missing, which I'm pretty sure is an idle issue. It's not my 4 wheeler. I'm working on it for a buddy. Someone started working on the original carb and 2 jets were missing when I got it to work on.
      So, I ordered a new carb. To get it to run, I had to adjust the throttle screw on the handle bar almost all of the way out. Even doing that, it still sounds like it's bogging down and missing.
      I did put a gas filter on it, which I'm questioning whether or not that's the issue and it's not getting enough gas like it should. The petcock only has an On, Reserve, and Prime option. It also has 2 ports. I guess I have the hoses hooked up right. There's no way to shut the gas off completely, and also it looks like there's no gas getting thru unless I run it on Prime. Reserve drips gas. I'm going to take it apart today and clean it. I'm also going to take the jets I need out of the new carb and put in the old one.
      I don't know what all this person did you the 4 wheeler before I got it. There's odds and ends missing that I've noticed so far. What else can I try or look for? What could be the gas issue with the carb and petcock? The carb was completely off the bike except hanging onto the throttle cable. The diagram I found for the carb doesn't help me with hose placements. Any help, or questions would be appreciated. I can attach photos if it would be of help.
