Join Today, It's Simple and FREE!
Similar Topics
By Scott Sirr
I need to figure out how to clean/fix or replace my neutral switch assembly On my 2008 Yamaha big bear 400 as generally the neutral light doesn’t come on when it is in neutral. To get it to come on I have to wiggle the foot shifter and hold it in just the right spot.
I have googled it and can’t find much on the 400’s. I can’t find a service manual online and the parts manual is super vague.
I think it is in the right side engine cover area, but not certain.
Any help would be great. thanks
Scott
By YamahaGrizzly
So my Yamaha grizzly 700 wasn't going into reverse for some reason but Jon and George figured it out on what to do to fix that problem for me. Jon Talks about how he was able to fix that problem my Yamaha Grizzly was having with the reverse.
On a side note we are so close to 1k subs! hell ya!
By Ryan Lewis
Went on a great ride on Sunday from the M-33 trail head to the Lupton trailhead in the Huron National Forest.
More videos from the ride to be uploaded to the channel soon.
By warrior
ok i have a 1987 yamaha warrior with a bad cdi i have found a good deal on one but it is a 89 not a 87 i have no problem with it not working and having to sell it but will installing and trying to fire the atv with this cdi ruin anything else ?????? i need to know sooner rather then later thank you
Similar Tagged Content
By YamahaBB350
I have a Yamaha Big Bear 350 and the reverse doesn’t work, it shifts from low to high easily but it won’t go back to reverse. I’m new to this stuff, so I’ll take any help. Any ideas?
By Colin James Krepela
So here's the deal people, I have an old Avenger 350 4X4 Shaft Driven ATV. They only made them in the early 80's their thought of as the first four wheelers from around back when Suzuki made one in 1982. I believe the engine on it is a Kohler as I watched this video https://www.bing.com/videos/search?q=avenger+400+atv&view=detail&mid=1E10E939019CA07770031E10E939019CA0777003&FORM=VIRE but mine is a 350. That's if its original, and it all looks original. I am wondering where I can get parts for this engine, or really what engine is it. I have no way to find the year, unless you guys know where a serial number might be. Every sticker is worn off. IF anyone has any information at all on these old wheelers it would be greatly appreciated. I specifically need the gaskets for the carb, and don't tell me I could build them please I want to restore it as perfectly as I can. I can take pictures of the wheeler/carb if it'll help. Let me know.
By oleskool
Has new top end, piston, rings, valves, etc. great compression, good spark, plenty of fuel. Valves have been set. timing has been tripled checked. Can not get it to start. any ideas suggestions on anything I am missing. Also if anyone has the service manual it would be greatly appreciated.
By Martin Carrière
Recently bought my BB. Everything works great. Only thing is, each time I put it in reverse, it either starts to rev high and start moving without giving it gas or I'll give it a bit of gas and let go and it will still rev at the same rpm or higher and keep moving. Doesn't do it for high or low.
