By marlon smith
By spigmef
I bought a 2008 arctic at 366 with 120hrs. When i red line it in neutral is smokes blue a lot. When I put it in high range it has problems getting over 35km/h. I bought it and had to clean the carb. It ran ok after i cleaned it. Not I have this problem.
By goatman
quad is a new to me freebie, pulled carb and cleaned it. got it running and idling nice but mid throttle it craps out and will go down to almost a stall, i release throttle and it just sits there idling away happy as a pig in poop. i was thinking fuel restriction then i noticed the exhaust glowing red in the sunlight. so its running lean
By goatman
bottom of the tail pipe was rusted out and the little nut also ripped off when i tried to undo it.
a 540 ml soup can is the same id as the exhaust pipe od and the soup can has ridges to make it a tight fit
a little bit of a mickey mouse fix but it works
By Sonders
Hey everyone. 2007 Sportsman 800 and the exhaust on passenger side is getting so hot it melted the bottom side of the seat. It's not low on coolant or anything. Any ideas what would cause the exhaust to get that hot?
