You've all asked for them and here they are pics and helmet cam video. I gotta thank Ichoptop again for editing my video its greatly appreicated bro and it looks better then I thought. As well as bot and his wife for sponsoring me and making a killer jersey I couldn't have done it without all my friends and family
[ame=http://www.youtube.com/watch?v=Ymb8kiwSHcA&feature=youtu.be]YouTube - ‪Pikes Peak Hill Climb 2011‬‏[/ame]
and my all time favorite pic from practice
Share this post
Link to post
Note that I had to cut some of the footage to get it under the YouTube time limit. I'm psyched and am thinking of a new project called "A Year to the Top" all about the trials and tribulations of a privateer and what it takes to get to the big race.
Share this post
Link to post
sounds killer to me bro if you need some footage or interviews ask me and my friends we'll tell you all about it:laugh:
Share this post
Link to post
I was nice I should put up videos of my friends garth and theo. Garth got ejected and got back up but theo high sided and slid about 50' on pavement only wearing moto gear.
Share this post
Link to post
  • Similar Topics
    • By Rich1028
      Video from Leota Michigan on our Honda 400's
      5-30-2020
      Was A nice Afternoon.
    • By AKATV
      For those that have been pulling hair out-
      It took me a month to figure this out, but I am glad to report that I have figured out how to repair my 2004 450ES Speedometer
      If you have a Honda Foreman 02-04 450 ES model ( 4 indicator lights on top of meter)
      or a Honda Foreman 99-00 450 ES model ( 3 indicator lights on top of meter)
      or aOnda Rancher 00-03 TRX350ES
      and your display:
      - Is Blank
      - does not show the gear indicator spot at all (not the gear or --) but the
      backwards "L" that goes around the gear position - its just blank
      -your miles and hours have reverted to zeros or all 9"s and possibly now shows KM now instead of Miles
      -your speed shown seems to have almost doubled (possibly KMs per hour even thought it shows Miles)
      What has happened is your EEPROM chip on motherboard has lost the programming due to dead battery for
      a LONG time or an electrical malfunction etc...
      I have borrowed a friends speedometer (a trusting friend) removed the chip from his, copied the data and put it on mine and it reads perfect now.
      I can repair your speedometer it will have 1851 miles and 317.2 hours on it as that is the only copy I have for the 02-04 Foreman 450ES
      I can also do 99-2000 450ES speedometers (3 indicator lights on top of meter) but will have to double-check check on the mileage/hours copy I have and let you know to see if you want that
      I can also do TRX500FM and FE meters and the older Rancher 350ES meters as well but it has to have the above symptoms and not water damaged-caught on fire, cracked lcd, etc....
      If you have one you want repaired just send to me (just the board with LCD) I can repair it for you for $45.00 or barter if you have a second bad meter for parts
      Shipping would be 4 - $5.00 for First Class with tracking and I will pay return shipping
      I will confirm and send pictures to you as well to show a working completed repair on your display
      If there is heavy water corrosion, rust and rot damage etc.. its probably not repairable but I can try if you want -no fix-no pay
      If you PM me or whatever we can work it out I am easy and like you all I am always fiddling/learning with wheelers
      I think you will be happy and you will have more hair -mine is filling back in...................
      Message me if interested
      I am now also doing burned out screen repair if your screen has become unreadable due to UV sunburn damage from the sun
      It will appear burned or melted.
      The cost is 45.00 with same or next day turnaround
      Will do partial barter if you have a second speedometer for parts
      PM me if interested
      Before and after pictures below
    • By Ellery Zandt
      I have no idea where the antifreeze line coming off the thermostat goes too. The carb two nipples in the pic create a vacumme. Can someone help me on this please....!!! my email direct is [email protected]!!!!
    • By Sombeech
      I shot this footage last weekend. We ran a Honda Foreman along the beach and had a great time wakeboarding.
      Helmetcam footage.
      There is also a download link for the YouTube Challenged employees at work.
  • Similar Tagged Content
    • By schreck562
      I got a 2011 king quad 400 asi thats fuel injected (throttle body) when machine is cold it runs great, after riding it for a while it gets extremely sluggish when ur just kinda cruising with a little bit of throttle applied, goin about 8-10mph with just a little bit of throttle it feels and sounds like the engine is struggling or under an extreme load, if u give it more throttle it will pick up and take off and run great, it seams to me i got fuel/air problem but know nothing of how to work on fi atv, i changed and used all grades of gas, changed plugs ( which r black as coal) , if u take aircleaner out it will run better for a little bit then it seems to get worse, it will also backfire when freewheeling or coasting down a hill whether its 1mph or 10mph short of taking it to the garage and raping my wallet i dont know where to go or what i can do do solve the issue if anything, i dont wanna have to spend $300 on a fuel programmer for a machine that should run fine without one, oh forgot to mention the kg is completely stock and only has 660 miles and 140 hrs, can anyone help???
    • By schmidtdm
      Hi all,
      Has anyone seen a 2011 Artic Cat 700 TRV owner manual?? Not the diesel but the gas version?
