You've all asked for them and here they are pics and helmet cam video. I gotta thank Ichoptop again for editing my video its greatly appreicated bro and it looks better then I thought. As well as bot and his wife for sponsoring me and making a killer jersey I couldn't have done it without all my friends and family
[ame=http://www.youtube.com/watch?v=Ymb8kiwSHcA&feature=youtu.be]YouTube - ‪Pikes Peak Hill Climb 2011‬‏[/ame]
and my all time favorite pic from practice
Note that I had to cut some of the footage to get it under the YouTube time limit. I'm psyched and am thinking of a new project called "A Year to the Top" all about the trials and tribulations of a privateer and what it takes to get to the big race.
sounds killer to me bro if you need some footage or interviews ask me and my friends we'll tell you all about it:laugh:
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By mikeexplorer
    • By Whiterabbit
      Hey all, from SW Virginia here. I just picked up a '01 Bombardier Quest 650 on the cheap (seller couldn't get it to start). After correctly plumbing the fuel pump (new pump the prior owner installed but had the hoses going backwards lol) and cleaning the carb and fuel tank, repaired all the batt - and batt+ connections she lives!!  I had swore to the wife unit I wouldn't be dragging another "project" home but I couldn't pass it up, it had new tires, new starter, new fuel pump and low hrs. All's good after she took it for a ride! 😆 It rides like a tank, very stable and tons of power.
    • By DayBreakJim
      20230725_171507.mp4
    • By Ulfthednar
      Just a quick test video while I'm learning to use my gopro (really, $250 discount I couldn't pass it up).
      This is from my side drive to the top of the property.
      The Dog loves the runs.
      No snowflakes were injured in the production of this video.
      https://youtu.be/tKjBFuHCkM0
