People who say ATV's are not safe has not tried to roller skate. I tried today and I thought to myself your getting the hang of this again after about 35yrs. of not skateing. Now I'am home with a big knot and an ice pack on my hip. I knew I should have stayed home an rode my quad.
:laugh:OUCH!!!!! What on earth are you doing roller skating !! I usually leave that for the younger folks !!!
My daughter twisted my finger and I thought "O" I was very good at it when I was younger and it tricked my brain in to thinking you can do this.
Kids have a way of doing that !!I`ve packed on 100 lbs since I skated last :biggrin:
Quadnut I've also pcked on at least 70lbs. & a 3 level lower back fusion L4-L5 & S1 3yrs. ago this Dec. I still have an acl ligment in my right knee that could not be fixed from a motorcycle 25yrs.ago I might need a roll cage on my quad & a 5 point harness with my luck.
I always said there are two kinds of people, those that are hangin in and those that are hangin on. It sounds like you picked the right name for yourself, but should maybe hang on a little tighter from now on.
    • By joezee13
    • By middlebrookgt
      Hi All.  I introduced myself some weeks ago with my 2006 LT-F400F that needed a list of repairs including replacing the cracked generator cover.  It is back together as of last night and cranks up, idles and revs high pretty well.  Needs some fine tuning and stop backfiring at stop.
      The big issue is it will not go into gear.  I reassembled the insides with help from y’all’s posts.  The transfer selector moves from H-L-R, and the foot shifter moves thru the gears and finds neutral easily enough.  Before I tear it back open, the  transfer selector on top does not move as far as the repair manual says.  The diagram shows the shaft moving something like 40 degrees between L and H and 50+ degrees between L and R but it doesn’t move that far even though it finds the indent areas and moves well.
      Could this be the problem.  I aligned all the dots on the shifter gears inside and it appeared to not be binding anywhere.  I do hear the gears touching when I shift like they are trying to engage, but zero movement from the ARV
      Are there better/bigger photos somewhere that would allow me to be confident I included all the washers and bushings, etc?  If I had any doubt on parts that were laying inside after the cover broke then I purchased replacements from online stores.
      TIA for any input or feedback!!  Pics are from when I first took the generator cover off.
    • By DexKing
      Hi my name is Dex, and i have an addic..oh wrong group.
      I only started actually riding atvs in late 2019 with a friend from high school. After getting out and enjoying a night of riding and camping, i just found that i REALLY enjoy being out in the woods on a 4wheeler day or night. my main rig is a 2020 Can Am Outlander 570 and recently picked up a 2004 Honda Recon 250, and a Kawasaki Prairie 360. Both the honda and the Kawasaki are projects that started in pretty rough condition and are slowly becoming running, riding machines. As i research and rebuild, i am learning new skills along the way and enjoying every minute of it. Thanks for having me in the community, i hope to learn a bit more every day from each of you out there, while also sharing some experiences with you all as well!
      I pulled out my Big Bear needed to do a few things probably havent been started in a year. Gassed it up charged the battery started right up. I have been using it around the property for this and that. Went to hook up my trailer to pull up to the house while it was idling it quit. Went to start it turned over but wouldnt start. After trying a few more times lost all power. Pulled it up to the house with the John Deere, the first thing i checked was the Universal fit soloenoil from Amazon and it was only a 10 AMP fuse so it does not universally fit the big bear it should be 30 AMP fuse. At the time i remember noticing it but forgot, at the time i had other problems like wiring harness being in a box stuck engine and no spark. when i bought it, yeah i know, thats one ishould have walked away from, but if i go to the trouble of hooking up my trailer and going there, its following me home.
      Thats old news, i still need to check it all out see if it lost spark and see if the starter shorted out it was acting kind of sluggish, i replaced the fuse with the spare 10 amp and blew immediately. I will try a 30 and see what happens.
    • By Ejwill
      I rebuilt the top end on my 2007 Honda Trx500fe. It ran fine right after the rebuilt. But now when I try to crank it it blows Bach through the carburetor. I held my hand over the opening for the intake air and it blew gas back on my hand. Can figure out what happened all of a sudden. It was cranking and was able to ride it running through all the gears. Now can get it to crank just blowing gas back to the air filter. Need help again. Starting to think I should have walked away from this one.
