Bombardier, Trax Max, 2003
Having problem with engine idle. Have to run higher RPM to keep it from dieing. Sometimes after running for half hour or so problem gets better, sometimes it doesn't. It just doesn't seem to be running right at low speeds.
Only has 250 miles.
Anyone have suggestions?
Thanks.
I agree about being a problem in the carburetor.
I don't live where it's located is the reason it has no more miles. We're usually there every month and always
run it some while there. I've used fuel stabilizer from day one.
A temporary fix would be nudge up idle speed but there is no adjustment on the carburetor that I can find.
swampcat... you say clean the carburetor. I suppose you mean tearing it down and washing in a cleaner solution?
If that does not work then you need to try to run the motor with the gas cap off. If it runs good with the cap off then it is the vent line that is under the tank that helps it breathe. Just clean that out.
BioWare,
I'll try your suggestion first.
Not sure if this has anything to with it. But I've noticed the fuel 3-way valve doesn't make any difference if it's turn to open
or closed. I once forgot to turn it to open but didn't effect the engine.
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By davefrombc
      1996-2003 Polaris Sportsman 400, 500, and Xplorer 500 service manual
      View File Polaris Sportsman 400, 500, and Xplorer 500 service manual
      This detailed, comprehensive manual covers the Polaris Sportsman 400, 500, and Xplorer 500 4x4 from 1996-2003.
      Submitter davefrombc Submitted 05/05/2026 Category Polaris ATV
    • By quadnut20
      Looking at replacing tires on my 2003 Foreman and was seeing what everyone is recommending fore it ?? Its mostly a plow machine but in the summer the  kids take it out !!
    • By digrig
      Hey everyone,
    • By ButchM
