sounds like dirty carb. if your lucky, you can try a can of spray carb cleaner thru it while its running, if that helps, there is a good brand of gas tank additive for cleaning (forgot the name of it). if worst case scenerio, if you have to pull the carb, use a non-chlor brake cleaner. you'll have better results than a carb clean.... IMO
    • By cfherrman
    • By flyinbrian365
      Factory service manual
    • By flyinbrian365
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
    • By Rockbottom
      What should i test next?
      thanks ahead
