A ring set from polarispartshouse.com is about $30.
I'd say at least a few hundred, to make it cheaper you could remove the engine from the frame and take that in which would lower their labor charges. I did it on a 110cc Chinese atv and it took me about 2 hours including taking the engine off the atv, but actually replacing the rings only took about 30-45 minutes. Good luck man
  • 5 weeks later...
ok i got the rings replaced. but now i put it all back together and theys a loud knock in the motor and it bucks in drive and when going backwards. any ideas on that??
no.... all i did was remove the top end. cylinder head and the middle part. chain guides and put back from a polaris page. i mean it starts and drives just a really bad knocking nose. i even did an oul change and put 41 oz like polaris say
is it like a heavy knock like a crank bearing or sorta a ping like a valve? can you feel the engine and kind of tell if it's top or bottom end?
the jumping forward and backwards might be a belt ...
there are a few polaris guys on here that might have a better idea, wylde1 and polarisrich i know off hand have them and do lots of work on their own ... maybe send them a message to look at the thread you posted ...
as dumb as this sounds,,,it was something I overlooked when I did my first piston job......make sure you replaced the gaskets with new ones, tighten the bolts down to spec (I had an air leak from not doing this correctly and my bike was over-revving and lunging forward) and check the intake for leaks......also, check your engine mounting bolts...Good luck!:wink:
hopefully you have a manual to go by for the tightening sequence and torque specs:yes: On mine, it was a pia to get to the left side head bolts cuz of the frame tube being in the way..had to use an open end wrench and turn it tiny bits at a time...it was a real learning experience, but now I know:wink:
I trick I use for finding air leaks is to spray a little carb cleaner around anywhere the air could be leaking. It will get sucked into the leak and you will know right away.
i know its a low class quad but y i got my quads motor all tore apart. how do i know what size piston to get? i thought it might be a better idea for my wife to just have alittle more power and thought it would be easier now.
    • By tds7
      Do any have any experience replacing 2001 Big Bear 400 Front Differential Input Shaft bearing and seal. Getting ready to buy one but the seal and bearing are bad. Any help would be appreciated.
    • By p5200
      I have a 1987 Suzuki dual range 230 and a 96 bayou 220. I'm trying to figure what oil to use. I normally put Amzoil synthetic in most everything. But I understand there are concerns over the wet clutch. I've heard rotella 10w40 full synthetic,5w40 synthetic,10w30&40 non synthetic. I do live in Michigan, so temps cold and hot are encountered. It could be below zero or 90 degrees farenhight. I don't have manuals for them. Any help is greatly appreciated!
    • By rgeiser
      just wondering if i pay the thirty dollars how soon will i be able to access the manuals?
    • By Matman
      Been working on this teardown for a while. Special tools are needed in a few key areas such as Flywheel puller, Crankshaft 52mm wrench, wet clutch puller, etc.
      I'm trying to get the wet clutch off now, and a few videos out there show it sliding right off.
      Mine isn't that easy.
      I measured the clutch's female threads and determined the puller spec needs to be 37mm x 1.5 LH Male.
      Anyone come across identical pullers from another mfg?
      The Suzuki tool is tough to track down and expensive for basically a slide hammer-type puller.
      Just need to figure out anther way to remove the wet clutch without applying too much pressure on the clutch plates to bend/break the plates or base. All thoughts are welcome to homemade tools. After this I need to cut out my own 52mm end wrench for the opposite side of the crank!
