Hey guys hope everyone is well. I need sum advice or help. Anyways I already rebuilt the carb however I noticed that the carb is spitting sum gas towards the airbox and i did a compression test and i only got 50lbs what should the compression be for these lil monsters bc 50 lbs isn't a lot I figure it will b around 100lb or so. So I'm thinkn a piston,bad valves? it does smoke white but I can get it to run but hard to start and I got to keep the slide all the way open on the carb to get it to even run but once I let the slide down it cuts off so its not even driveable right now plz help me guys trying to get it running b4 we get snow
Thanks ox I knew it was to low. so what u think bad piston rings or bad valve? It is spitting a lil gas out towards airbox, so I'm guessing air is sumhow getting out and pushing sum gas out of carb.
valves and timing can also be the prob... i would check and see how tight the valves are adjusted ... if you have a service manual on it ...it will tell you how to do this ... and you can also check the timing that way ... it almost sounds like the timing chain might have jumped 1 tooth ..
Thanks guys unfortunately I dnt have a book so I dnt know how to check timing and valves I'm pretty much doin this with out a book and mainly guess wrk. It does have around 5k miles on her and the recent owner didn't maintain it very well. Any tips on how to check that stuff. If I have to break it down anyone know where I can get a good performance cam for it and get it bored to next size hopefully that will give me sum extra power
So today I set my valves however still a no go. I set intake at .004 and exhaust at .006 now I'm geting backfire thru the carb and cnt get it to start at all also put a new plug in. Any other ideas guys? And yes it was on tdc
So I set my valves again and it cranked up first time it ran about 2 mins then cut off I got valves set int .004 exhaust .005 I put it on tdc by taking plug out and feeling for air then use the hand starter to put piston on top I got needle jet about 2.5 turns out should I turn it in some so I can get it to idle. And got new spark plug gapped at .26 any tips guys or ideas what I should do or check
What's up ox. Naw I dnt know y it shut off. When I reset the valves she cranked as soon as I turned it over. I do have my air mix screw turned all the way in til I can get it to idle and get it set however when it did crank it didn't idle high with the air mixture all the way in which it shud have. I'm thinking its fuel problem bc when I took old plug out it was extremely black and had residue on it as well so burning rich right?. I got the needle jet set at 2.5 turns out frm seated. It's almost bck to same problem it will crank if I raise the slider half way up to give it more air
I just thought about sumthn the needle that goes in the slide which way does it go in? Do the grooves and clip need to b up or down? I think this is my problem its to cold and dark to mess with it right now so I'm gonna try it tomm
I got it to idle and kinda wnts to bog when I give it gas then after playing with it a while I can give it gas however when I give it full throttle for about a min she will cut off and I noticed the float bowl is completely dry! Any ideas ? Bad float or bad float spacing or sumthn
Checked compression its at 95psi now so better then b4. bout to check timing shortly gotta figure out how to check that I got plastic off I kno how to line cam gear but not crankshaft part I'm sure its simple
Could be bad fuel lines or fuel filter/pump. Pilot screw setting might be closed too. And your going to want the valves a 6 thousandths and maybe even 7 thousandths for the exhaust valve because it will expand a little with the heat.
And make sure you run premium fuel in there because anything else is terrible on the carbs
Edited by Thayer40
I hvnt had much time but i did put a new float in it. Still bog when I give it full throttle but Idles good my book said pilot needs to be 2.5 out but il try 3 and readjust valves again il let u kno what happens when I get a chance to mess with it
    • By BillR94
    • By HHurks
      Hi to all
    • By WeeBee
    • By Kurt Reiser
      My quad will not run with the airbox hooked up  Will not go past quarter throttle as soon as you unhook the tube at the back of the carburetor it runs great  does anybody have any ideas what it could be I have a bad fuel pump one on the way can that cause the quad to run like that
    • By MOORETARHEELS
      I have a 2006 LT 80 done a top end rebuild and only have 80psi.  Any suggestions on what it could be.
