How far do you go for maintainance?
By kevinohio
By middlebrookgt
By Rick Shropshire
By Werewolf
Airbox is getting oil in it from crankcase vent, the engine has 2 cups of oil when I drain it. I drained it out put it back in the reservoir, prime it start it up after a few minutes it starts spitting oil out?
By Need-help-with-quads
