technofarmer
What Does A Linhai Owner Think?
Hello everyone. I have the Linhai 400 UTV and I am having clutch problems. I have to shut the engine off in order to change gears. Do I need to replace the clutch? If so, anything on the web to help?
Also, does your Linhai UTV have a loud "whine" when you are traveling in it? We bought this new in December 2012 and has done this since day 1.
I am also in GA (middle GA), what dealership do you use?
Thanks in advance for any help!
Share this post
Link to post
have no idea man thats the downfall with theses machines very little information i feel they shouldnt sell a motorvehicle unless they sell a complete taredown and literature specefications shop manual so we can service and learn them ourselves guess we will have to wait tell someone decides to print one
Share this post
Link to post
  • Similar Topics
      For anyone looking for ATC 3-wheeler service and repair manuals, please check our our downloads section under ATV Repair manuals.
      Thank you to @oxidized_black @Maggie Hall @northernmi for their contributions.
      Here are some of the ATV 3-wheeler repair manuals currently available. Please add to our downloads if you have some to share.
    • By AKATV
      For those that have been pulling hair out-
      It took me a month to figure this out, but I am glad to report that I have figured out how to repair my 2004 450ES Speedometer
      If you have a Honda Foreman 02-04 450 ES model ( 4 indicator lights on top of meter)
      or a Honda Foreman 99-00 450 ES model ( 3 indicator lights on top of meter)
      or aOnda Rancher 00-03 TRX350ES
      and your display:
      - Is Blank
      - does not show the gear indicator spot at all (not the gear or --) but the
      backwards "L" that goes around the gear position - its just blank
      -your miles and hours have reverted to zeros or all 9"s and possibly now shows KM now instead of Miles
      -your speed shown seems to have almost doubled (possibly KMs per hour even thought it shows Miles)
      What has happened is your EEPROM chip on motherboard has lost the programming due to dead battery for
      a LONG time or an electrical malfunction etc...
      I have borrowed a friends speedometer (a trusting friend) removed the chip from his, copied the data and put it on mine and it reads perfect now.
      I can repair your speedometer it will have 1851 miles and 317.2 hours on it as that is the only copy I have for the 02-04 Foreman 450ES
      I can also do 99-2000 450ES speedometers (3 indicator lights on top of meter) but will have to double-check check on the mileage/hours copy I have and let you know to see if you want that
      I can also do TRX500FM and FE meters and the older Rancher 350ES meters as well but it has to have the above symptoms and not water damaged-caught on fire, cracked lcd, etc....
      If you have one you want repaired just send to me (just the board with LCD) I can repair it for you for $45.00 or barter if you have a second bad meter for parts
      Shipping would be 4 - $5.00 for First Class with tracking and I will pay return shipping
      I will confirm and send pictures to you as well to show a working completed repair on your display
      If there is heavy water corrosion, rust and rot damage etc.. its probably not repairable but I can try if you want -no fix-no pay
      If you PM me or whatever we can work it out I am easy and like you all I am always fiddling/learning with wheelers
      I think you will be happy and you will have more hair -mine is filling back in...................
      Message me if interested
      I am now also doing burned out screen repair if your screen has become unreadable due to UV sunburn damage from the sun
      It will appear burned or melted.
      The cost is 45.00 with same or next day turnaround
      Will do partial barter if you have a second speedometer for parts
      PM me if interested
      Before and after pictures below
    • By Jeremy Morris
      If you're getting that pesky leaky seal on the pinion of your front differential and the pinion has allot of play, polaris won't sell the bushing needed to repair it properly without having to shell out big bucks for the complete ring and pinion kit.
      I have a kit with an upgraded bushing, Japanese made bearing and USmade seal
      50 shipped in the US and 55 to Canada
    • By Chris Chitwood
      Hi, I’m a 16 year old that is wanting to get more into vehicle and mechanic repair. My dad has an old ‘96 Timberwolf that he doesn’t remember running since I was born. I want to get it running again as a memory for him and to help us be able to hunt together, and of course so I can learn how engines work more than the little information I know now. I’ve pulled the carburetor and gas tank off of it, and the carburetor is getting cleaned by a friend. I can post photos of the condition it’s in later, I’m just curious where I should start in my journey to get it running again. The power switch is broken off of the handlebar, so I am looking into fixing it, along with the pull cord. I’m afraid the engine is seized up, and I’m curious to hear any input anyone has. Thank you all.
  • Similar Tagged Content
    • By Devin Hazelwood
      I have a problem finding a wiring harness for this particular ATV. Does anyone know were I can get one or were I can get one that's from a different name but similar harnesses?
      Linhai 260-300 ATV Parts Manual
      View File Linhai 260-300 ATV Parts Manual
      Submitter Admin Submitted 07/01/2019 Category Other ATV
    • By oxidized_black
      Linhai (german)
      http://rapidshare.com/files/3880403675/Linhai%20(german).rar
      Linhai 250 - 360 Service Manual
      http://rapidshare.com/files/582921063/Linhai%20250%20-%20360%20Service%20Manual.pdf
      Linhai 260 - 300 Parts Manual
      http://rapidshare.com/files/1587211864/Linhai%20260%20-%20300%20Parts%20Manual.pdf
      Linhai 260 - 300 Service Manual
      http://rapidshare.com/files/3400427719/Linhai%20260%20-%20300%20Service%20Manual.pdf
      Linhai 300 Parts Manual
      http://rapidshare.com/files/1938660329/Linhai%20300%20Parts%20Manual.pdf
      Linhai 260 Service Manual
      http://rapidshare.com/files/218261873/Linhai%20ATV%20Service%20Manual.pdf
      Linhai Bighorn CUV Service Manual
      http://rapidshare.com/files/2459140573/Linhai%20Bighorn%20CUV%20Service%20Manual.pdf
      View File Linhai 300 ATV Parts Manual
