You are a Ford Mustang!
You're an American classic -- fast, strong, and bold. You're not snobby or pretentious, but you have what it takes to give anyone a run for their money.
I'm a Chevrolet Corvette.You're a classic - powerful, athletic, and competitive. You're all about winning the race and getting the job done. While you have a practical everyday side, you get wild when anyone pushes your pedal. You hate to lose, but you hardly ever do.</b> <p>
    • By pastorjeep
      Need a little help fixing a no spark issue. 2002 BT with the 2 wire ignition switch. I have 4 stators and 2 CDI's and 3 coils to test. The new stator reads 218 ohm, and .2 ohm, the one that came out of it reads 50K and .2, the other is 132 and .2. All of the coils are 0.00 ohm, and there is no way to test the CDI that I know. I have also confirmed the replacement stator pins match the factory locations. I did try to test milli-volts at the coil to see if it was getting any signal from the CDI but nope. IDEAS?
    • By lester
      I picked up a 2000 Big Bear 400 4X4 that was sitting around that I know nothing about. It will not start. I do have a red light when in reverse. When I take it out of reverse, I do not get a green neutral light, and when I push the start button the red oil light comes on but there are no noises, nothing else happens. How do I test the neutral switch and/or bypass it to see if I can get it to at least crank? And does anyone have other suggestions for me to try?
    • By lewisrssll
      View File How To Perform Compression Test
      How to perform compresion test
      Submitter lewisrssll Submitted 10/06/2024 Category Other ATV
      The AMA U.S. ATV Motocross Team of Bryce Ford, Joel Hetrick and Brandon Hoag dominated in the Czech Republic at the 2024 Federation Internationale de Motocyclisme (FIM) Quadcross of Nations. It marks the sixth time that the team has secured a global championship since 2017.View the full article
