In from IL
gth1985
Hello,
Just purchased my first quad from a buddy. It is a project, he was trying to get one of his cows back to the pen when she took a sharp left and flipped him multiple times. Needless to say she needs some TLC, so did he.
It is a 97 Yamaha 350 Big bear AWD. Fires up and runs like a top without any work done yet.
From what my visual inspection led to;
U-Joints are toast.
inner CV boots are torn.
Muffler does not muffle.
Tires are trashed - also filled with slime (Farm quad)
Plastics could be worse.
Brakes are inop.
Racks look like it got flipped by a cow.
Idle screw is bent, but functions.
Other than that, she drives and shifts half way decent. CV boots and brakes are first on the agenda, then making her quiet down some.
If there are any tips or tricks you guys can think of to help a newbie out, I'd appreciate it.
For example... I know the tires are full of slime, which i equate to fix-a-flat. In my auto expirience this stuff sucks. When it comes time to replace the tires, anything I should be aware of wheel wise?
Also, if anyone knows a place to get slightly used functioning parts I would also be interested.
TL;DR - Got a quad and JD LX 188 Mower for a good deal, now time to fix em'!
  • Similar Topics
    • By Ejwill
      Headlights and taillights will not work, the dash light will not come on. Already checked fuses they are all good. Help please. 2006 Honda rancher 350 es.
    • By 97kingquad
    • By DaDolt
      So, I found myself in the only 5' deep water hole in Moab with the King Quad. Before I could get off it swallowed water at idle and died. The river water was not very clean. I pulled the plug and pumped the water out of it with the starter. I cranked on it and it popped for a second and then was done. Towed it back to the trailer. When I got home I checked the compression and it had none. I have a factory service manual. Disassembled and found the rings stuck in the piston lands. New rings and back together. I try to start it and get a C12 code CKP - crank position sensor. Troubleshoot and find it to be shorted. Installed aftermarket CKP, still get code. Check voltage on new CKP and only get 4.5V, manual calls for 5V minimum. Pulled every connector apart on vehicle and cleaned. Have continuity from CKP sensor side of connector to ECM harness. Install a known good ECM from another 2005 KQ I have. Vehicle fires and I let it run for 10 minutes. Shut it down and put the original ECM in and get a C12 code again and won't fire. Put the known good ECM back in and get C12 and no fire. Tested both ECM's in the other KQ and runs well on both ECM's. Installed a used stator and CKP. Still get a C12 code. Check used stator, 200 ohms and 6.5 V out of the CKP at the ECM harness. Checked ground at ECM harness and it is good. Checked spark with spark plug and without, none. Checked resistance and peak voltage on coil and it is in spec.
      This thing has me baffled. All of the electrical possibilities seem to check out. Might be far fetched, but could the rotor key have sheared when it shut down suddenly when the cylinder filled with water? I know rotary lawn mowers can shear the flywheel key when the blade stops suddenly from a rock or stump. If the key is sheared and the flywheel is out of time by a few degrees could this be giving the C12 code? The voltage output is correct but at the wrong crankshaft position (wrong time).
    • Get More For Your Device
    • By AussieKingQuad
      View File 2007-2010 Suzuki King Quad 450 AXI service manual
      Submitter AussieKingQuad Submitted 11/23/2023 Category Suzuki ATV
  • Gallery Images
