My 2007 Arctic Cat 500 is acting up. I hope its just needing a new belt, but has anyone seen this before. Jumps when starting rolling in all gears. Once gets going its fine as long as you stay on gas. It feels like starting off in a rzr (takes a second to engage)
    • By noticon75
    • By tepin
    • By Shorty51
    • By Jdeaton011989
