Hi
Just picked up a BB for $650 as the PO just threw in the white towel. There is no spark with either the electric start or pull start. The stator is new, new battery, new key switch, new plug.
I have gone over every wire and cleaned everything and checked all I could with multimeter.
I'm stumped myself why I wouldn't get any spark with theh pull start.
Could this be the pickup coil?
wires coming out of stator are red and white, green and brown, and 3 yellow wires
I get continuity from red and white but nothing from green and brown or the yellows
Its a hair puller and hoping its just the pickup coil and not the cdi
thanks
when i replaced the stator on my '91, i had to switch the 2 wires out in the connector off the stator. a red and white i believe. i had the same thing happen as you. found the instruction/data sheet and told to do just that ...
When you say you had to switch the 2 wires, do you mean you went from red to white and white to red or some other combination using the original wires against the new wires?? I'm only asking as I don't have the paper work for this supposedly new stator that was installed in bike before I purchased it.
I will post pictures later today
Tested the pickup coil and stator and here are my readings
red and white = 318 ohms (pickup coil)
green and brown = 272 ohms not sure what these wires are for
I also tried swapping the red and white and still nothing.
Would the low reading on red and white mean a bad pickup coil?
The reading for the green - brown seems to be on the low end of the numbers I read. I should have (270-330 ohms) and the low reading for the pickup is way below the numbers I read (459-561 ohms)
I've also got a new CDI waiting to be ordered.
if you haven't ordered a new cdi, i have a used one from my 91 which is good. the PO replaced everything electrical on my bike but left the stator. i replaced the stator and all was good ...
i'll look into the readings, there's a manual in post#3 in the yamaha atv manual section if you need one ...
Just curious.
Would you know if a CDI for a 1996 Yamaha Warrior YFM350 is compatible with a 1995 Big Bear YFM350?
I can purchase one at a real steal of a deal, but would only purchase if it's compatible.
Just curious.
just looked on bike bandit and different numbers for cdi. i looked at my 91 and its the same.
you are in winnipeg? if you want my used one i'll give it to you. just pay me for the shipping.
Update on the Bear.
Tore into carb and cleaned it up. Didn't need much cleaning as it appeared spotless and all gaskets already looked new. Found the rubber on the intake between carb and motor was torn and split in 2.
For now going to use a plumbing coupling as a temporary fix.
Starting on rear brake caliper as it was caked with mud, hay, an grass. The brake pedal arm looks bent and not really doing anything. The hand brake lever is loose and sloppy on the brake mechanism on rear wheel.
I took cover off and rotor looks good, but I did notice I cannot line up the marks on the arm at the back as it was installed the wrong way. It appears I need to remove axle nut to take off wheel hub to remove brakes.
Easier said then done. I've been soaking it in PB Blaster then using a 3/4" drive breaker bar and beating it with BF hammer and haven't budge it.
Will keep trying .........:aargh:
Edited by ddiggerr
Opened dust cover on rear brakes and got them apart. PO had busted the wings off wing nut at end of brake pedal rod and the brake lever wing nut was seized on. What a pain getting those off.
Brakes were just caked with more mud and crud. Got new brake lever cable and will get everything cleaned and back together. I will need to figure out the brake pedal rod though. Looks like its too long and was replaced with whatever was available to the PO.
Never did get axle nut loose and at this point, I'm not going to try breaking it loose at this time.
sent some pics of the cdi unit to your mail here. the numbers are close and one connection looks diff to me but if it will work ... a friend of mine said you might be able to use it as long as we share the same spark plug. my machine uises an NGK DR8EA
It's been confrmed, I need to replace the CDI. I spoke with the Yamaha dealer here and he advised me that the previous owner brought the quad in to be checked out.
I was also advised that the previous owner was told he needed to replace the CDI. It would have been nice to know this information when I bought it. Oh well, maybe he thought I wouldn't buy it if I knew about the CDI.
Next I need to replace the intake manifold, as the rubber holding it together tore in half.
That can of worms is getting bigger everyday ....... :skeptic:
**SOLVED**
Readjusted everything and they seem to be working now. MAN !!! are my fingers numb. Friggn' cold outside!
I adjusted the rear brakes per manual, however I will also be replacing brake handle cable and need to figure out this rear brake pedal rod.
Does anyoe know what the correct length of this rod is suppose to be from end to end?
Once I hook it up and spin on the wing nuts (as far as they will go on), my foot still almost touches the ground when the brakes are applied. The brake lever on the brakes themselve stop where they should, however the rod appears to be too long and gives alot of travel, too much travel.
Will attept to attach photos in a bit
Edited by ddiggerr
Grrrrr .....
New question. I believe I have a switch on rear brake lever that requires me to have brake applied to start and at the same time the run switch needs to be on, key switch on, and bike in neutral.
My issue is, all I need to do is turn key, put into neutral and push start button and motor turns over. Is it suppose to turn over even if the kill switch is set to off, brake not applied or is it suppose to do nothing until all 4 requirements are set?
I find it odd that it would even turn over with kill switch set to off.
:mad:
Hmmm ....
checked the ignition coil today. My multi reader has settings of 20K, 200K, 2000K, 200, and 2000
My readings were:
Primary coil at 200 = 1.0 ohms
Secondary at 20K = 17.07 ohms
I was not getting a reading for the primary on anyother setting. The reading for the secondary was about the same on others.
I even cut back the end of the plug wire 1/2" with no change.
Going by these readings, is the ignition coil my culprit?
My source is reading 240 ohms and my pickup is reading 280 ohms. According to manual these are way off. Man .... I am so confused on these readings. Not sure whats good and whats bad ...
Edited by ddiggerr
CDI rewiring finally done after 3-4 hours of searching the web to match everything up. Now just waiting for ingition coil and stator/pickup from dealer.
Hopefully today
Stator arrived today and I wasted no time getting it installed. I was surprised when it fired up first try.
Took it for a rip through the snow out front and buried it .... hahaha
A few more things to put back together and it will be good to go
Found a new problem . I went for a long cruise last night to test it out. It seems to have engine knock at high RPMs. Probably just needs the vavles adjusted, so thats next on the list tomorrow.
Also the front diff, driveshaft, and axles were removed prior to purchase so I'll be on the hunt for those missing items.
Until then, thanks for all the help and CDI
  • 6 years later...
Create an account
Register a new account
Sign in
Sign In Now
    • By DaleJAM
    • By ruslan1o1
      Hey everyone looking for a suggestion of where i can start looking. But first I'd like to explain what happened. Took the bike this morning got it started in 6 degrees celsius in 6-7 kicks? No choke. Drove 6km and when shifted to next gear bike decided to just shut off, stopped checked everything out seemed good, started first kick and on i went, drove maybe another 2km bike did same thing but this time it took me 10-15 kicks to get it started, on the third time after a kilometer decided not to start at all. Kicked it like a 450 a couple hundred times, nothing. So far checked gas is good, bypassed fuel filter and on/off valve to eliminate that problem, hot wired the kill switch in case something got corroded there. Nothing. Any suggestions would be welcomed. (Heard valve adjustment are a must do?)
    • By Bobbles
      New to the forum here, hoping someone can help. I have replaced the cdi, coil and sparkplug yet still no spark. The measurements for the igniter and stator are what they are supposed to be, the kill switch is working as it should, the neutral light is working as well. Any ideas where else to look before i start trying to pull it apart for the stator and igniter?
    • By darklord19991
      We rebuilt the engine put wiring back together it ran before but now it won’t and has a weak spark we have been trying to figure it out for about a week and still nothing changes does anyone have any help on what it might be?
