Hello, I have a 2005 Suzuki Eiger Quad runner. 400 4x4 Auto
Starts ok. But when I push on the throttle, it stalls. Maybe the carb needs adjusted?
There is some kind adjustment wheel that turns. I suppose this adjust fuel/air mix to carb. Either way I turn that, it still stalls when gas applied.
Our Suzuki dealer is no longer here, Honda will not work on it...:mad:
Edited by bigisland
Stoopid question...but have you checked to make sure the fuel shut-off valve is on? The fuel petcock.
Another reason could be that the carb float is stuck down. If the quad sits, it can be a problem where the float pin oxidizes and sticks the movement of the float, essentially causing a fuel starvation scenario. :yes:
Had the same problem with my 07. Twice. Both times it was something foreign finding its way into the carb. This last time, was a damned bug. Best guess it got in through the vent line found just in front of your left nut. Installing a screen on that line next time I have spare time.
    • By Fonne
      Hi
    • By Elk
      2002 Polaris Magnum 325
    • By jay41198
    • By LMI
    • By kevinohio
