Labor Day Weekend!
  • 2 years later...
  • 11 months later...
I just finished cutting my 1 acre lawn, which I have not cut in almost 2 months due to drought...I'm freaking winded!!LOL.. Tomorrow going to some friends in Long Island and hopefully to the beach one last time on Monday...:biggrin:
You need to turn that acre of grass into an acre of dirt and mud, so you can ride on it instead of mow it.:yes:
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By NZrider
    • By jatho
    • By mkibbe
