DON'T RIDE ALONE, UNSAFE, LET ME KNOW
By kawasig
Hello there
By BuckBilly
By DarkRider
Hey everybody,
Just curious on some opinions on my recent buy. I'm a big fan of the drivetrain and transmission in the Suzuki King Quad 300 and QuadRunner 250 4wd models. I've been wanting one of either model for quite some time, and recently picked up a really nice shape one for 1500. I just wanted to get some opinions on whether you'd be more hesitant to get something this old, if there are newer options that are comparable.
Also just keep in mind this is coming from someone not super mechanical.
Key factors:
Engine doesn't appear to have any leaks Had to replace the battery for $100, no biggie Front left CV boot is torn (not yet sure if the axle has damage) Starts right up with the tap of the button every time (so far) Idle was a bit low and was shutting off when warm. Adjusted the idle. Now it will only shut off occasionally on a hill if I'm not rolling or giving it gas. Has a Harbor Freight Badland winch with a wireless remote (brand new, tested and working) Has brand new shocks and brakes Shifting gears and changing between 2wd/4wd/diff lock/high/low/super low all seem fine. Rides pretty good, tight steering, takes the bumps pretty good as I have pretty rough trails. Brand new tires Over 2000 miles, that's quite a bit, but it seems well cared for. Plastics are almost all there. It's really only missing a small bit of the black mud flap in the rear. Has minimal stitching in the front, and it's got the usual scuffs. All of the lights work just fine (Neutral, Reverse, high and low beams) Tested the charging system and that works
And I think that's just about all I can think of at the moment. It mostly seems to be complete and all there. I was a little hesitant about getting something that old, as parts are always a concern. Looks like most parts are available, but axles seem to be hard to get if you want something brand new. I really wanted a 2000's model but I couldn't pass up the price.
By Gwbarm
It seems every ATV i look at to buy used has no title, does everyone loose there title, or do they change hands so often the title is lost in the shuffle. The ones that do have titles are triple the price. I am new to buying used quads is this pretty standard procedure.
I know all quads are good and tough but thought it might be good to hear opinions as to what member think is the best, from your experiences.
By alexwv1863
Hey everyone, I have an issue with my dad's 03 Yamaha Kodiak 400. It had been running great but he left it sitting for a short amount of time. When he started it, it ran fine for a little bit but all of a sudden it quit taking gas. I thought it may have been the carb because it him not running it. The carb ended up being pretty clean. He put it back on and after taking it off and cleaning again, I'm beginning to wonder what it could be. It'll start and idle just fine, but when you go to give it throttle, it'll die out. It sounds like it's not getting air right but idk where to look or what else it could be. I'm stumped and need to figure this out before I go crazy. Anyone have any ideas???
