2000 polaris sportsman 335 speedo failure no AWD
Rushville
check the wheel sensor to se if it has become fouled with mud or something. if not jack it up discontect the wires hook on a multimeter and spin the wheel to see if it is making voltage. an abs sensor is just a small voltage generator that sends a signal to the ecm to let it know the wheel is turning.  probably also sends a signal to the speedo.
  • 2 years later...
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By Spritee1
      not sure where to look next
    • By Slitzer
      Hi,
      What I understand is correlation code for brakesensors, very little information in workshop manual.
    • By kiriyaaoi
    • By luckyyyyesther
      Hey all!
