I received this set this week and used them.
Could not be happier.  You strip the wires put them into the connector and hit them with some heat.   The tube shrinks and has a gasket material that melts and surrounds the wires, then there is a strip of soft solder that melts as well connecting the wires.
Very strong.
50 pcs Solder Seal Heat Shrink Butt Connectors Electrical Marine Automotive Waterproof Wire Splice Insulated Connector Kit 26 24 22 20 18 16 14 12 10 Gauge AWG https://www.amazon.com/dp/B01LK2YJQC/ref=cm_sw_r_cp_api_i_RZ-GCb3N1M9Q1
  • Like 3
Very strong.
[emoji1303]
I'm getting those.... thanks for posting the link...
Sent from my SM-N950U1 using Tapatalk
This is a great tip!!!  The heat active adhesive used makes a great seal  I've used marine grade heat shrink connectors (splice an mating) for the past ~6 years with our boat, and not a single issue related to the connector with steady salt water exposure.
Note:  Make sure you line everything up well.  The heat activated glue doesn't let go once adhered.......not an issue of you have plenty of conductor length, just cut it off.  If you're short on wire, prepare accordingly.
    • Guest Fox300exchic
      By Guest Fox300exchic
      Here's mine...
    • By Freedomflyer
      MGoing to apologize in advance to those that have a soft spot for wolves. They are definitely not my favorite species of animal.  They continue to grow bolder and bolder even with the population exploding all around us in this wide open valley floor. This valley is approximately 40 miles long by 35 miles wide. Was once mostly agricultural but over the last 25+ years, the kids of long time property owners have sold to the highest bidder.  Developers buying up small farms and ranches for millions of dollars and eating away at the local agricultural way of life, destroying the rural Montana I, and many natives, once knew, covering up perfect farm land with urban sprawl, never again to produce a grain of wheat or barley,  potato,  canola seed, or any crop of any kind ever  again.  Lining developers pockets, raping and pillaging another rural area and leaving the infrastructure in a colossal mess and the local cities trying to figure out how to pay for the improvements to move the traffic, overloading an already overloaded tax base.
      FINALLY, after years of farmers and ranchers lobbying and legislation, they finally opened up a season to hunt the destructive and devastating consequences of the reintroduction of wolves into Yellowstone National Park. These animals have become a huge problem outside of the park boundary. Did the powers that be actually think these killing machines would stay inside the park boundaries? Really? Hmmmmm, not the sharpest tools in the shed. Their population has exploded over their reintroduction into the park in 1995. They released 41 wolves into different areas in Yellowstone Park, then made it illegal to kill any of them that came out of the park boundaries. Pretty much leaving farmers and ranchers defenseless in protecting their livelihood without becoming a criminal. If they did ever shoot one the investigation process has been so stringent and stressful a lot of them have done the 3 S's. Shoot, Shovel, and Shutup! There are now over 1500 wolves in western Montana, over 1100 in Idaho, over 400 in Wyoming, and almost 150 in Eastern Washington. Who knows how many have migrated back into Canada.
      They finally delisted the wolves and opened up a hunting season on them, something that should have been done years ago before they decimated our elk population.
      A friend of ours was able procure a tag and was able to fill it yesterday morning. The wolf was down in the middle of the valley floor stalking his cattle on his family ranch, definitely deserved to be taken out. Personally would like to see more taken down, they have gone well beyond repopulation with this program and have spent millions on tracking and thousands of man hours, colossal waste. Glad to see another one gone.
    • By mattgoodwin
      I'm repairing a 96 Timberwolf 2x4. Many years ago a dog chewed the wires that go from stator to the rectifier/regulator, and I've had to use the pull start ever since. Ive since lost the plug for the stator and on the wiring harness side. I'm ordering a new stator that will also come with the female plug that I need to fix it on the wiring harness side, but I have no clue in what position to put those 3 white wires(ones I'm holding with electrical tape on them) back into the new plug. Since they're all the same color, does it matter? Any info on this or pictures anyone has of their own will be very much appreciated.
    • By picriver
      new ignition switch
      four wires - green, red black, black with white line
      atv four wires - pink, pink with white line, black, red
      which is attached to which, please and thank you?
    • By RRP
      My new 2023 Polaris Sportsman 850 is in the shop for a pinched Wiring Harness from the factory...
      I did one ride on it (100kms), then to the shop for a month, waiting for them to replace it with a new one.
