I live in Utah so sometimes we get a fair amount of snow.  Is the cost of a snow blade/plow worth it, or is it a pain do to on an ATV?  What brands/kinds work best?
I have had a plow on my quad for years. Well worth it, Here in the Northeast we sometimes get heavy wet snow which is a pain to use a snowblower. A plow works well.
The winch is used to raise/lower the blade, some models will have a manual lift. All depends on your machine and plow
Mike
how much snow will it push?  up a hill?  So say I have a plow on my sportsman 500 (over 1000 pounds), will it push a foot of snow?  My dad says it wont- that trucks even have a hard time pushing up hills after it gets to two or three feet...he worked for a lawn care company and plowed snow for i think 7 yrs mostly with a 450 diesel flatbed with a ton of salt on the rear...
and what about gravel?  Can you lift the plow just a little to scrap over the surface without relaying the driveway? :wacko:
can make it low to the ground or higher.
I used one without even manual lift (just an adjustable strap) this "snow season". I would put a 40# bag of salt on the front rack to help compress shocks to keep it lower as well. it does ok for the most part, well worth the price in metal!
  • Thanks 1
Well the snow at my place in North Dakota was like powder! so it was not an issue. If I was going to plow snow here in California, wet and heavy, I would buy chains, and make sure I had a powered lift so I could take smaller passes.
i have an 05 Kodiak. Yamaha plow system and Warn winch. The plow is fine. Winch operation is the way to go. However, my issue is the way the plow mounts on the Kodiak. The tubes run under the frame and attach to a plate. This may be fine for the average owner but i do a lot of trail riding and I have to remove the plow mounting plate each spring to install my full skid plate and vise-versa in the fall.
Why not just leave the mount on year round?? The mount forces you to leave a lot of under carriage exposed to rocks and branches. i went as far as to cut up the old plastic skid plate and and mount it ahead and after the plow mount. Its ok for some brush but not rock hopping, etc.
  • 3 months later...
  • 5 weeks later...
Plows are absolutely worth it if you have a driveway or road to maintain. My dad and I each have a plow on our machines at the cabin. I have a basic 5 foot blade, and he has the tapered county plow style blade where it throws snow to the right. I'll usually start by driving down the center and angling my blade all the way to the right, then he follows behind with the tapered blade and throws it over the shoulder. In regards to how much they can push you'd be surprised. I live in northern mn and multiple feet of snow isn't uncommon. You can start your initial pushing with your blade up and only work half the amount at a time. We've maintained our driveway and a good portion of cabin road through multiple heavy winters where banks can get 3 to 4 feet high. Of course everything has a breaking point and if it gets to it we will eventually get the snowblower out and work the edges blowing the banks into the woods, but it takes a while to get that point. The key is to start you winter season pushing it as far over and out of the way as possible and then hope for some warmups that'll melt it back a bit.
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
      Best ATV for Older Riders
      Polaris Sportsman 570 EPS
      Best Reliable ATV for Seniors
      Honda FourTrax Rancher EPS
      Best Features
      Best Premium Comfort ATV
      Can-Am Outlander MAX
      Standout Comfort Features
      Best ATV for Easy Handling
      Suzuki KingQuad 500AXi
      Why Older Riders Like It
      Yamaha Grizzly 700 EPS
      Best Features
      Arctic Cat Alterra 600 TRV
      Key Advantages
      Electric Power Steering (EPS)
      Automatic Transmission
      Lower Seat Height
      Two-Up Models
      Hand Warmers and Heated Grips
      Adjustable Suspension
      Buying Too Much Power
      Ignoring EPS
      Choosing Aggressive Tires
      For most mature riders:
      Final Thoughts
    • By middlebrookgt
    • By Matthew Alloway
      What is the best paint for a swing arm. I know powdercoat would be the best, but I am looking for paint type that I can easily do at home.
