Melted electrical connection...what to do?
So I put a headlight wiring kit from LMC Truck on my '96 Cherokee that circumvents the normal wiring and runs the headlights directly off the battery by way of a relay.  The kit runs the lights at 55/100 (low, hi) watts instead of the original 55/60.  One reason I did this was because the light output was terrible, and the other was because for some unknown reason the headlights would shut off after being on hi for a bit.  Never did this on low.  I've had the new wiring kit on for a few years now and it seems to have solved the issue.
The problem I'm having now though is that this new harness is melting at one of the connections...
You can see only one of the wires is overheating while the other seems to be ok.  I'm guessing the hot one is used by the high beams.
What could be causing this?  Could it be related to why the high beams used to shut off before I replaced the wiring harness?  A while back I asked about the shutting off issue on a number of Jeep boards but nobody had heard of this particular problem before.
If you can fix that wire for a quick test that would help.
Take an amp probe and put it around the wire with and without the high beams on.   See what your reading.  That’s the first thing I would do.  If that wire is coming from a relay then there’s a problem with the wire set up. Maybe an overload on that one wire where there shouldn’t be.  But do that test first and see what the amperage is.
I noticed the butt splice in the photo is also showing signs of burning out. Clear indication of an overload. Is there an inline fuse with this kit? The photo does not show one. Any connection directly to the battery needs an inline fuse. It is dangerous not to have that, in the event of a short, that wire will get red hot and arc out.
Wire gauge appears to be correct (14 gauge) for a 100 watt kit, so you seem to have an overload condition.
Mike
I agree with the guys on get an amp clamp on there so you know how many amps your pulling, and put an inline fuse near your battery.
My guess is you have a short in the light bar when on high... On high you it should read about 8.333 Amps,
Just an option, but I would cut out any traditional but splices, and replace with a soldered connection and shrink tube. I have been testing Solder Seal connectors from amazon and they seem to be working really well. You just need a heat gun to install. They take a little practice but work well.  For marine applications I add an additional section of shrink tube over the solder seal connector to make it extra water tight and a tougher layer of insulation.
Frank,
I am glad to hear someone else is having good luck with the Solder Seal connectors.
On a side note, I have been surprised at the quality of support Quad Crazy members are providing for the less experienced.  In the short time I have been a member, I have noticed you latch on to a difficult problem and logically walk them through trouble shooting it.  I was originally just looking to pick up the service manual for my quads, and now find myself checking in, and seeing if I have anything meaning full to contribute. I am no mechanic, but work on industrial control systems so I can often contribute on basic electrical issues.
Thanks for the comments I appreciate it but im a small potato here compared to some of the other members.
I was in need of some help on a problem I was having I came across Quadcrazy and got some really good help here. After that I was always checking in.
So I think it’s about two years now I’ve been a member and countless bikes later I enjoy paying it forward and helping others as so many of our other fellow members do as well as having other members help me out on my problems.
Edited by Frank Angerano
best site i found in long time and the help rocks just a thanks from us Elmer Fudds trying to do what our parents did to save money but stuff has been made harder on purpose.I have fixed my stuff but have had to go to dealer on my Rhino wiring problem and they said never saw a problem like that before ever so I lucky to have a smarter dealer who guys care.
Keep it great stuff coming but must say I had hundreds of toys like quads bikes skidoos over the years and well guess I have had problems mostly melt downs on older skidoos the bikes and quads are better \I guess 4 stroke is better just costs more.I miss my old ITs yamahas had every size from 125 to 465 490 much more fun then the other one which I cannot think of the two initials I want to say CR but thats Honda.I love Hondas too maybe more more really but all good. Too bad the chinese 2 strokes are over but most were junk really.The cost difference is scary really I bought new pocket bikes for under 100.oo Canadian delivered for that price amazing really.
I put this is wrong place but had to say to other my 2cents worth :Lol Enjoy this site everyone
That’s a great post @scotty2hotty01 I am a big Honda fan.  Yes CR was the initials.  I hand my first cr80 and it was a great bike.
Ran the heck out of it and quickly went up to a 125 then 250 and swapped over to the Kawasaki where I raced my as* off for a few years.  Then off to ATV’S...... Still like Kawasaki but always loyal to my Honda and always looking to figure out the next brand and project which I’m hoping will be a Suzuki. It’s really the only atv I’ve yet to get my hands on.
We will see what happens, right now I have this Kawasaki Mojave on the table and have had zero time to play with it.
#Quadcrazy
i was thinking YZ as was a yamaha fan back when |I was young loved the IT as rode in mountains mostly yz were for tracks more as had to keep them in power band the it you could jump over logs what ever hit it away you went.So much fun back in the 80 I ud=se to buy and sell to keep my kids in gas and smaller bikes.My youngest was 18 months old when he got his 1st little 60 had them 70 trikes but some as***** stole them from inside our yard.I still cannot believe that give your kid a hot trike some bad dad for sure I hate thieves.Keep up your great posts bro enjoyed by  many!!!
  • Thanks 1
    • By adr94
      Hello,
      I was able to repair most of the little problems on my 2006 BRUIN. I still have little things to do...
      I changed the Hazard light Switch because it was not locking when pushed and now it is not working at all. When I connect it (not sure of the wiring -4 wires but a lot of connection possible on this HELLA 3916-01 switch-) the flashing lights button (on the handlebar) is acting like the Hazard light switch.
    • By rmundell
      We most often go out in our 96 GC, It has a 6" long arm lift kit on 33" tires. V8, front air locker, rear lunchbox locker.
      This way here in AZ we are inside in A/C staying out of the dust!
      We use OnX off road through Android Auto on the double din Pioneer we have fitted it with.
    • By Fish0rDie
      Well yall, it's been a while. Work has absolutely annihilated me for the past 5-6 months, and ive had bare minimum time to work on this project. Thank you to those that helped previously during the engine rebuild, but now were on to the task of wiring, and let me tell you besides the plugs on the wiring, I am almost completely lost. Bought an ebay harness, and none of the colors line up to what i have seen on any manuals. Its all the 97-01 electronics i believe. Ill post some pictures below of the mess I'm working with. Emphasis on "mess." A lot of the wires had to be extended since the harness was made for an atv and not a buggy. The colors are a little wonky, but I was using what I had, and they were mostly for just extending the plugs, so the colors match on either end. A buddy of mine has been helping me, and we are just at a loss. Looking for general guidance or any wire specific help you could give us. Not even sure if some of the single wires are plugged in right, and we dont have a "lever switch" wondering if thats just for the brake, because the master cylinder has two screws. I suppose a + and -... We also have what I believe are the reverse and neutral sensors to plug in (the only two sensors on the engine)
      P.S. peep the custom airbox i 3d printed to utilize a lawn mower filter and 2x2 coupling from lowes
      If you need better pictures of anything, let me know, It's kind of hard to get pictures of this rats nest.
      Wires that are not connected to anything
      4th picture black wire
      5th picture blue wire w white stripe left/solid blue on right
      6th picture what I believe to be the lever switch from pictures I saw on ebay
      7th picture is two black wires coming out of the harness. One we have running back to a black with white stripe that comes out of a different place in the harness. The other that had an end to match the single wire coming from the handle bar switch. Single handle bar wire has a white stripe, so I may try to switch those around if the ends permit it.
      I know it just looks god awful, but i really do think we are close, and the idea is to figure out whats going where, then figure out how to make it look better, so bear with me haha. Any help is appreciated. Just finished a little go kart for my wife with a predator 212, and gosh do I envy that wiring (there is none😂)
    • By p5200
      Hello folks, I have a Polaris 500 Scrambler. Not positive I need a new battery.  The folks I got the ride from said they put a new battery on it right before selling it to me. It's been a couple cold months before I tried starting it. After jumping it now, I let it idle plus revved it quite a bit for about 20 minutes. Then I shut it off and tried to restart barely turns over and that's it? Am I not giving it enough charge time maybe need to actually ride it? The battery on it is a Continental CTX9-BX. I lf a new battery is needed would maybe Amazon have a decent one? Thanks!
    • By GTX-Racer
      I am looking for a front battery cover for a Suzuki Quadrunner 250 (year unknown).  It has the headlight on the handle bars and no speedometer.
