Lets see them quads ladies!
Guest Fox300exchic
wow. that looks badass! mine's getting done hot pink.[ like HOT ,almost red] remember, you are on the ladies page. =] haha. but i gotta get new riding gear or else that would be like a pink bomb went off.
and as for the trx450's.. i smoke 'em on the dragstirp. every.single.time. buuut then again none of like that THAT. :]
Not exactly where I'm suppose to be but let me be the first to welcome you. This is a very fun and family friendly site. Enjoy!!!
Feel free to chime in on any conversation going on, start a new one, what ever! Have fun. Don't hesitate to ask any questions, we have certified mechanics in our staff and others that just no way to much stuff for their own good. Oh yeah, we also have people that are just certified!:laugh:
  • 7 years later...
  • 4 months later...
    • By NZrider
    • By jatho
    • By mkibbe
    • By jatho
    • By hardcastle
