By jay41198
By Gwbarm
I generally use Non Ethynol fuel in all my small engines. I just got back from the gas station and that fuel has really increased in price since last year, I will continue to use it, even though its north of 1.00 a gallon more. That seems minor compared to cleaning and repairing carbs every year.
I was just curious as to what others are doing in regard to gas in their quads, i know a lot of the newer ones are fuel injected which shouldnt pose a problem, but i have had lots of problems with rust and jell forming in carbs when using ethynol fuel.
By captnunu
I have a 2007 kingquad 450 fuel injection. I try to start it with the hand crank and almost flip over the quad. I have taken the hand crank off and cleaned it but this did not fix the problem. I believe there is a decompression valve that is supposed to engage when pulling it over by hand. How can I check this?
By ButchM
By Zrach
I wanted to share a successful workaround for a "no-spark" issue on a 2009 LT-A400.
This is specifically for cases where the CDI has been diagnosed as faulty, but the age or condition of the machine makes the cost of a brand-new OEM unit hard to justify.
Note: This modification compromises the factory “no-start” circuits.
On some malfunctioning CDI units the internally damaged circuitry is only partial.
Feeding full time power to the Parking Brake pin, the unit is triggered to bypass the internal fault and produce a healthy consistent output to the Ignition coil.
The Modification
See the second diagram attached below for the wiring specifics.
The Result:
The machine has clocked over 1,000km since this repair and is still running strong with no ignition dropouts.
⚠️ IMPORTANT SAFETY WARNING ⚠️
Please be aware that this modification compromises the factory safety "no-start" circuits.
The machine will now start in gear. The safety interlock involving the handbrake is no longer functional. The machine can move unexpectedly if the starter is pressed while in gear. Proceed at your own risk. If you sell the machine or let others ride it, ensure they are fully aware that these factory safety buffers have been removed.
Faulty CDI Workaround.pdf
