Ok....Here is a question;    My Kawasaki Concours (1992 so it has four (4) air sucking behemoth carburetors) has a 7.5 gal fuel tank. The Club wisdom was to add 1  ounce of two cycle oil to ever fill up......HMMMmmmmmm?   good idea?
BTW my concours has 94K miles on it....just saying
Nothing wrong with doing that the 2 cycle oil just gives the engine a little more top end lubrication while running and that is not enough oil to cause any plug fowling problems. I am assuming that is abbout a 4 gallon tank.
All my 4-cycle engines (without a catalytic converter) get a little 2-cycle oil mixed with the gas. The pistons and valves love it, never fouls plugs. "Upper cylinder lube" is what the additive bottles call their snake oils. My mix ratio is 1 ounce for 2 gallons gas.
  • Thanks 1
You could also use Seafoam as an additive, it will also help keep the fuel system clean
I use Seafoam regularly in all my equipment & have for years! Works great !
Added the receiver hitch.  Here is pic with ball installed.  The max tongue weight is 30 lbs.  850 towing weight.
Foreman really looks studly with hitch!...🥰
Wow, I didn't realize the receiver hitch was a bolt on option.  My old foreman has the mount tongue welded onto the axle so no chance of conversion without reweld.
Good deal!
My diesel tractor has the same ball-hitch setup. Very convenient. My two balls are 2" & 2,5/16" the larger ball is for moving the camper around on the ranch. Much easier than using the pickup truck
Speaking of which My old neighbor would start his Big John Deere Diesel and let it run for 15 minutes in the summer before he would move it..  During cold weather maybe 20 5 minutes.   He said it was better to get it up to temperature.   I star my VW sand rail and let him run for at east two minutes before moving.  I try to do the same with most vehicles.
Very smart. All internal combustion engines should be started gently and allowed to idle for at least five minutes. We're all in so much of a hurry and have no patience. Turbine powered aircraft have timers incorporated into the start procedure
Ok here is the light trailer I picked up some months ago....What's  wrong with this picture??!!! the hitch is on the wrong end!  OMG!  Even with the mechanical winch on the tongue it has negative tongue weight.  I could not tow it without having more than 100 lbs at front of trailer as it would 'fish tail'.  But it has brand new LED lights (Wiring is Neanderthal vintage) and new axle,  rubber, and bearing " buddies".  It also has a release so the bed will tilt down for drive on loading.   I am going to somehow make the lights just flash so if i tow it on the  paved road on way to back property.  I want to carry mower to use to clear some trails.
  • Sad 1
I am going to just use it here in the woods.   Unbelievable poor design.  However. I am limited to 30 lbs hitch wt one Foreman so I can manage that with tis trailer.  The Yamaha 700 can toe it also
There are a lot of custom made accessories made for the HOnda ATV.....Cannot make up my mind...Still not sure about a "hard" plasttic storage / seat Vs the soft storage / seat.  The hard plastic is probably difficult t remove but probably more easy to use.
Not sure of Honda's but Arctic Cats come with an accessory port in the rear of the machine that has power for attachments. You could make up a quick harness to connect to it and the trailer to light up the trailer lights.
Another option is to tap into the tailight so the trailer can have running & brake lights.
Yes  Forman has a 12 vdc power supply outlet..   I would rather just have tail lights flash with no power cord.  But  you are probably correct that would be easiest.   The exposed wiring on the trailer will get torn off as Forman drags her though the woods.
It shouldn't be very difficult to  move the axle back  to center about where the trailer light / license  plate is now.
You could tap into the brake light  wiring easily to add brake lights to it ; and as far as accessory sockets go, it is also  quite easy to add one to your quad.  I  added one to both the front and rear of my '91 Honda Fourtax 300 4x4
Edited by davefrombc
Yes...You are probably right.  The axle/ bearings and wheels are new.   The bed tilts which is nice.   If i did that maybe i could modify it so my Yamaha Viking would fit on it.  The Viking weighs 1448 lbs and is 64 inches wide.   Currently the Viking only fits on my heavy 16 ft  trailer that i have to pull with my Tundra.    The Forman is only 44 in wide and easily fits on my light trailer.
So relevant to a Rear Storage /seat for the Forman, one guy told me that the hard case Rear Storage/seat tend to bruise the passenger if rough terain riding.  Whereas, the Raer Bag storage /seat does not impact the passenger.
Hmmmmm?
      Best ATV for Older Riders
      Polaris Sportsman 570 EPS
      Best Reliable ATV for Seniors
      Honda FourTrax Rancher EPS
      Best Features
      Best Premium Comfort ATV
      Can-Am Outlander MAX
      Standout Comfort Features
      Best ATV for Easy Handling
      Suzuki KingQuad 500AXi
      Why Older Riders Like It
      Yamaha Grizzly 700 EPS
      Best Features
      Arctic Cat Alterra 600 TRV
      Key Advantages
      Electric Power Steering (EPS)
      Automatic Transmission
      Lower Seat Height
      Two-Up Models
      Hand Warmers and Heated Grips
      Adjustable Suspension
      Buying Too Much Power
      Ignoring EPS
      Choosing Aggressive Tires
      For most mature riders:
      Final Thoughts
    • By Frank Angerano
    • By sunn
      I have an older 2000 Honda 450 ES which has been a tremendous workhorse since owning it new.  I'm now looking to update neglected maintenance on the machine, looking for advice initially on brake work?
