Ajmboy its a04 Suzuki TwinPeaks 700V-Twin thanks
outlander560 there 1.5 (1-forbelt exhaust 1-forbelt inlet 2-for airbox)=4 pipes all together, i did not have to rejet either. it also has a 2"HL lift&HL springs, Rad. Relocated, And strobe lights
thanks for the info but y do u have to for the airbox? i got the highlifter springs for my cat their really good.. soon i will be getting a lift kit. how r ur front axles doing with the lift kit... is that a camaro i see in the back
Edited by outlander560
outlander560 the reason i ran 2 is i ran 1 did not run good so i said i'm scared(ha ha) to cut a hole in the airbox but you have to so i did it. It runs real good no sputtering are nothing good on take off,runs smooth.Have not had a problem with my axles at all with the lift until i had to pull a polaris about a mile to camp. the pull rope caught a tree in one of the turns and jerked me back into a wheelie and when it came down snap front right tire caught a root cv joint broke, other than that good. And yes it is a 68 Camaro, a little toy i've been working on. it has a little 327 in it right now(750HP right now)150 shot of laughing gas, got my eye on a 572 though.
thank you Stoopidbot1
from block up, found it in a field when i was clearing the trees off this old mans land. i asked him if he would sell it he said you can have it its been there for 15 years, i had the camaro body and thats when it all started.i've worked real hard on it with all the extra money i had, and alot i mean alot of time on it. then had my son Wyatt which is now 4. i had been working on it 2 years before he was born, bought new house and 5ac. of land so money has been a little tight. so i've been saving money here and there to try to finish, spending a little bit on that 4wheeler.
Your very welcome! My Brother-in-law has a 69 Z28 with a 302DZ in it he is finishing up. He also has a 70 Chevelle LS6 all original except paint that he bought from the original owner and that 67 Vette that he is starting to restore. He has others but those are the big dogs.
    • By Kawiherder
      It starts and runs Ok but after a while the temp gage lights up and the fan fails to start.  Any suggestions on where to start looking would be helpful.  Thanks
    • By RamzV
      We have multiple riders in our group, looking for more people to ride with. I am also a certified powersport tech so if anyone needs any work done look up Neptune powersports on fb
    • By tjakes680
      So I recently cleaned my carb on my 1986 Quadrunner 230GE and had to replace my fuel pump and now it seems im getting to much air and I can not use carb to adjust it I believe its coming in from either my air box or one of the air ducts or possibly the clear air container that is under front of quad that runs into the air filter bag but im not sure. Has anyone have any experience with this happening quad will idle super high and nothing can lower it except blocking off a air duct that leads to main air box i also have to check again for any cracks or leaks in air lines and box and ducts any advice will help im stumped ! What else can cause to much air coming in ? Could it be a leak from engine or top end ?
    • By bigboy123
      When running for a while the rancher will shut off without the fan turning on. We then took it to dealer where it was started and warmed up. The fan came on at the dealer so they then replaced the fuel filter and fuel pump. We got it back and ran good for a few days with the fan coming on when needed. Now its back to shutting off before the fan ever comes on. It seems like the time the fan should come on the bike shuts off. It will start after letting it sit for a few minutes. Any ideas of the problem?
    • By Airborne
      The country has been changing fast, this past year the current happenings have given my wife and i a new perspective on things .
      we have discussed possibly moving out of our current state ,our state Government is a disaster, currently looking into Montana , weve been researching it and like many things about it ,the weather is what we like as well as the freedom .. Wondering if there are any members that are familiar with the state and would chime in on this ?
