Where do you take your cat?
As time goes by and I approach 2000 miles on my H1 engine I am starting to think about what mods I want to do and what stock parts need to be replaced. My friend has a 400 and almost has 2k and has done alot less service work than I did. Well I think the larger tires and the places I take my cat are the reason. So where has your cat been?
I would also be intrested in what mods you have done.
Well besides being on its side from a 35mph +/- rollover here are some pics.
well i havent really taken that many pics because of the same reasons you have mike..ill post a few just at the local train track trails...how is lost trails atv park?? i have always been wanting to go their...anyway as for mods: warn winch with synthetic rope, 26"itp mudlites on itp rims, 1.5 inch moose lift(modified because they dont make one for independent cats) HL springs, raider hand guards, epi clutch kit purple secondary and orange primary springs, front and rear bumpers, and a k&n filter with pre-filter... i did break one thing that really sucked it was my right rear axle besides that nothing major and i have 975 miles on her
here is one of the trails running along the taconic...might be posting some action pics of it in the swamp and at the race track... but as for now i only have 1 sorry fellas
snowatv.jpg[/img]
Edited by outlander560
Mine's pretty stock except the bumpers, winch, hand guards, etc. The one thing that made a difference was the 26" Bighorns on ITP's. They made it a lot easier to manage. So far the only thing that should get some attention is the spike load dampener. It's not slipping bad, but I should get it replaced while I still have warranty. I've only got around 600 miles on it so far, so there's plenty of time for something to go on it.
Mike, I love that pic of you crawling out of the mud pit
I've got a few pics, but having some trouble. It says they're not a valid image.
I didn't make it out of the pit because my tires were worn out. I plan to put the bighorns on my LE rims when I get a few $$ together. For now I am using the ex-swampcat tires :coolgleamAc:
Mike
Mike
It was sure fun watching that cat claw, though! It was amazing what you were able to do with those old tires. Your new/old stockers will be a lot better, but wait till you get the Bighorns, what a difference.:yes:
I am looking for a set of spacers for the mud tires and then some engine mods.
I might clip the spring in the carb and drill the slide this spring, still thinking about it.
I also want to arrange some things to help me better in the mud pit. I raced a few times this summer and did average.
The second time (above) I had minor carb issues. The 1st run was awsome but the 2nd I think I took a bit of water on. Had a exhaust snorkel made.
The Third (below) was the first time I ran the 29.5s the only problem was the mud pit was more a pond with a hard botton. Should have switched back to the XTRs, my decision killed me. With the new clutching I hope this is a thing of the past.
  • 5 months later...
BTT - what has everyone been upto? Is there any interest in a East Coast Arctic Cat ride? I know I can get at least 20 AC riders and have some cool places that would host it.
Here is a vid of the latest ride we did with the cats.
-by9qLGUpKs
And then a poker run from this last saturday (With the Teryx)
rKHnD3DGug0
      Hello there
    • By Jhb12686
      Hello I appreciate the welcome into the group. I am beyond frustrated with this desperate search for parts. I have a 2013 XY power sports UTV 300. I had a catastrophic failure in my rear differential which resulted in the destruction of almost everything inside. I have located everything I need to completely redo the rear end. But I cannot find a short side axle shaft with six splines etc. it's an offset differential and one shaft is longer than the other and I need the short one. The tip of it broke off (pic). Any help in getting another shaft for this thing would be GREATLY appreciated. Thanks guys
    • By DarkRider
      Hey everybody,
      Just curious on some opinions on my recent buy. I'm a big fan of the drivetrain and transmission in the Suzuki King Quad 300 and QuadRunner 250 4wd models. I've been wanting one of either model for quite some time, and recently picked up a really nice shape one for 1500. I just wanted to get some opinions on whether you'd be more hesitant to get something this old, if there are newer options that are comparable.
      Also just keep in mind this is coming from someone not super mechanical.
      Key factors:
      Engine doesn't appear to have any leaks Had to replace the battery for $100, no biggie Front left CV boot is torn (not yet sure if the axle has damage) Starts right up with the tap of the button every time (so far) Idle was a bit low and was shutting off when warm. Adjusted the idle. Now it will only shut off occasionally on a hill if I'm not rolling or giving it gas. Has a Harbor Freight Badland winch with a wireless remote (brand new, tested and working) Has brand new shocks and brakes Shifting gears and changing between 2wd/4wd/diff lock/high/low/super low all seem fine. Rides pretty good, tight steering, takes the bumps pretty good as I have pretty rough trails. Brand new tires Over 2000 miles, that's quite a bit, but it seems well cared for. Plastics are almost all there. It's really only missing a small bit of the black mud flap in the rear. Has minimal stitching in the front, and it's got the usual scuffs. All of the lights work just fine (Neutral, Reverse, high and low beams) Tested the charging system and that works
      And I think that's just about all I can think of at the moment. It mostly seems to be complete and all there. I was a little hesitant about getting something that old, as parts are always a concern. Looks like most parts are available, but axles seem to be hard to get if you want something brand new. I really wanted a 2000's model but I couldn't pass up the price.
      If you're an outdoor enthusiast looking for adventure and off-road fun, an all-terrain vehicle (ATV) is an excellent choice. ATVs have become increasingly popular over the years, offering power, versatility, and excitement for riders of all skill levels. As we dive into 2023, let's take a look at some of the best ATVs the market has to offer.
      1. Yamaha Grizzly 700
      The Yamaha Grizzly 700 is a top contender in the ATV world. Its powerful 686cc engine delivers excellent performance, whether you're traversing rugged terrains or towing heavy loads. With Yamaha's Ultramatic transmission, the Grizzly 700 offers smooth and seamless gear shifting, making it a joy to ride. Its advanced suspension system ensures superior handling and comfort, while features like electronic power steering and On-Command 4WD add to its versatility.
      2. Polaris Sportsman XP 1000
      The Polaris Sportsman XP 1000 is another top-rated ATV known for its power and performance. Equipped with a 952cc engine, it delivers impressive acceleration and speed, perfect for adrenaline junkies. Its high ground clearance and active descent control provide excellent off-road capabilities, while the electronic power steering ensures easy maneuverability. The Sportsman XP 1000 also offers ample storage space, making it a practical choice for longer adventures.
      3. Can-Am Outlander X mr 1000R
      The Can-Am Outlander X mr 1000R is designed for those who crave extreme off-roading experiences. With a 976cc engine and a specially designed mud-ready transmission, it's built to tackle the toughest terrains. The Outlander X mr 1000R features snorkel air intake and relocate differential breathers to provide exceptional water fording capabilities. Its aggressive mud tires and sturdy suspension ensure maximum traction and durability, making it an ideal choice for off-road enthusiasts.
      4. Honda FourTrax Rancher
      The Honda FourTrax Rancher is a reliable and versatile ATV suitable for a variety of outdoor activities. Powered by a 420cc engine, it offers smooth power delivery and excellent fuel efficiency. Its compact size and lightweight design make it maneuverable in tight trails, while the independent rear suspension provides a comfortable ride. The FourTrax Rancher also features Honda's Electric Shift Program, allowing you to effortlessly change gears with the push of a button.
      As you explore the market for your next ATV adventure, keep these top 2023 models in mind. Whether you prioritize power, versatility, or reliability, these ATVs offer exceptional performance and features to enhance your off-road experiences. Get ready to embrace the thrill of the outdoors and take on new adventures with one of these remarkable machines!
      Do you agree? Comment below
