It happens when the float is not leveling off and shutting off fuel flow. In the past I would have to shut off the fuel flow switch when parked, not to loose gas.
* Added year, make, and model to your thread title.
I have to agree with Ajmboy your fuel is not shutting off....i had this issue with my atc not to long ago i took my carb apart and cleaned my float and the float needle and whala works like a charm
the neddle or the float is stuck have it rebiult by someone that knows whats going on until the after ridding turn the gas off people dont know this while your bike is ridding around in the back of your truck or trailer your float is steady working because of bounceing causing gas to sloashing in the bowl and there for over filling it and its got to go somewhere into the clyders out the over flow i suggest turning off the gas run out the in the carb DO NOT ATTEMPT ON 2 STROKES and if to much fuel gets dumped into the clyders it can bend your rods.
    • By Atomusthenes
    • By Tim Keiper
    • By Dumass
