Napa sells a cheap 12v round light, black cased and roughly the same size as the stockers, maybe a bit smaller. A friend of mine uses them on his Tecate, they work great for him. Come to think of it, I have the same lights in the front of my Blazer, here is what they look like.
dont put auto parts store ones on there they wont last, get a set off ebay or craigslist for cheap, they fit off warriors and banshees alike, even some yamaha 4x4s just not sure which ones, but the aut parts stor ones dont last unless you buy the expensive ones, i have been telling people for years, my buddy wouldnt listen to me and put foglights from a car on his suzuki, lasted one ride and one shatteres and the other filled with mud, i orderes him ones of ebay for 20 bucks for the pair, plugged them in, bolted them in the correct factory designed position and they have been working fine for over a year now :-)
Not every situation is going to be the same, my friend has been running the same pair of "auto parts store" lights on his Tecate for the last 6 years with no problems. The lenses are actually pretty thick and durable on thes particular ones.
    • By Arizona
    • By Peisledder
      Hello, can someone help me? I have a MAP error code 102-3, and the MAP has 4 wires: light blue, orange, purple, yellow. I’m getting different results on what the wires are. I don’t have wiring diagram. Can someone confirm which is ground, 5v, MAP, and Temperature?
    • By Rick Shropshire
    • By davefrombc
      I added a pdf of  the wiring of the various connectors used in vehicle socket  and trailer plug wiring to the  "Other ATV files"  section in downloads.
    • By Need-help-with-quads
