Ice racing at rainbow falls
Dream Car Giveaway
Well the bolt in the axle is still stuck in there lol, but i have some plans to get that out, and the clutch basket is really REALLY loose on the clutch gear and was making noise, so i ether need to get a new one like a rekluse basket or somehow mod mine to stop the wobble. And then i just have to put it all back together :3
For the cost of the rekluse I would save a little more and get a hinson basket instead. Rekluses are nice but I haven't met anyone with one that worked properly.
Im trying to mod my stock one, by doing the same thing that rekluse does with their basket by drilling the studs out so i can separate the gear from the basket and then threading the basket so i can bolt it back together and then ill put some shims next to the rubber dampeners to stop the wobble
Everyone I have talked to loves their Rekluse.
I've seen two different guys on yfz's with rekluse clutches lock up in 1st gear while racing. Blame it on improper install on them but I know with the kawi 450 there's been a few that have done the same thing, never heard a reason why though. And the only reason I really say hinson is cause a lot of race teams use it. Granted they ridiculously expensive but if they can hold up to racers abuse it should hold up to our. :laugh:
 Share
  • Similar Topics
    • By slide187
      So I changed out the steel winch cable on my CForce 800-2 to a synthetic I had gotten when I had my old outlander and just never put it on. That wasn’t too difficult but I had to open up the hole in the spool a bit to get the tail thru. But I got it thru put the set screw back in and wound it up. It’s one of those Amsteel type cables, 50’ with an 8’ sliding protection sleeve on the hook end. And I put on an aluminum hawse with a rubber stopper and new hook. (Which is like the Warn Epic hook. Might be a little big. Haha ¯\_(ツ)_/¯)
      And right before that, I pulled out the halogen headlights. Replaced them with these nifty dual color LEDs. (But because of the heat sinks on them I had to widen out the holes for the bulbs a little and then vacuum all the dust out of the light housing with an improvised headlight vacuum. Haha)
      But they fit and the lights are yellow on regular beam and high beam switches them white).
    • By Rich1028
      St Charles MI. Bad River Quads on the ICE! 1-29-2022
    • By Wayne Gilroy
      I currently have a 2015 Polaris 570SP that I bought new and have been riding for for over 20 years.
      I don't do much trail riding or mudding like I used to when I was younger.  I mostly use it around my 25 acres in the country as a utility vehicle (moving trailers, working on hunting stands and gathering firewood in the woods).   The work in the woods sometimes tests the stock tires, but most the time I'm on high and dry ground.  And every once in a while the wife and I will get together with some other atv friends and go for a day of trail riding.  Maybe 2 or 3 times a year give or take.
      I use the ATV year round, but here in Northwest Wisconsin, the snow depth makes it prohibitive to getting out in the woods or out on the frozen lake.
      I don't want a snowmobile (they are such a bi*** to get un-stuck in deep snow - I know because I have a friends 500lb sled stuck in 3 feet of snow and slush on the lake right now).
      So I'm thinking about getting a tracked machine.  I've never driven one, but have watched several youtube videos that are quite impressive.  Especially for snow.
      I have seen some systems are geared for snow only, and some that are all terrain.   I would prefer to use a track system year round unless someone can convince me it's better to have tracks just for snow and wheels the rest of the year.
      My questions are:
      1. Between a Can Am 1000 and a Polaris 1000 - which one is better for tracks? I'm familiar with the Polaris AWD system and like it.  I've "heard" that Can Am's 4wd isn't quite as good, but maybe that's not true.  I'm open to other machines but these two are just my preference.
      2. Tracks - all season vs winter.
      How much of a pain in the as* is it to change from tracks to wheels to tracks each year?  Are the snow only tracks worth it vs year round tracks?  Can you comfortably trail ride (non winter) with tracks?  I'm talking long, boring, well groomed, straight, flat dirt trails.  At the end of 50 miles am I going to wish I had put the wheels on? How long are tracks good for?  My machine will be garage stored and my annual mileage/hours will be minimal.  Are there any things to be aware of in terms of warranty violation if I were to buy a new machine and put tracks on it myself vs the dealer? Any issues with stock axles, clutch or other components? Thanks in advance!
    • By Rock Ledge Homestead
      I bought this four-wheeler used for my son's birthday last week. It wasn't running when I got it but after a new battery and some tinkering it has been running for 5 days probably 8-10 hours of run time.
      Today after 1 hour  My son wanted to wash it, I showed him how to be careful not getting water near the engine. We were careful but after we washed it and let it dry the motor starts but the transmission slips and won't really go forward.  Even if I pick the back of the four wheeler up the wheels only go forward a tiny bit. It's as if something is slipping inside.   But it worked fine right before the wash.
      Not sure what brand. I was told it was 90 cc's the VIN is attached.  Is it 90 or 110ccs?
      No air filter came with it. Using a some old stockings until I figure out what air filter to order.
      My son is so bummed so I want to get it back up to speed but also teach him how to work on it.
      20200620_184911.mp4
    • Dream Car Giveaway
    • By Ellery Zandt
      I have no idea where the antifreeze line coming off the thermostat goes too. The carb two nipples in the pic create a vacumme. Can someone help me on this please....!!! my email direct is [email protected]!!!!
  • Similar Tagged Content
  • Gallery Images
