I recently rebuilt the top end of the motor and rebuild of the carb. It was smoking real bad and hard to start. Now it starts right up and shoots out white smoke and oil out of the tailpipe. It also idles fast with no adjustment on the idle screw . What can be my problem?
dennisg
I had the piston replaced and the cylinder fitted to a new one and the head finished by a service shop and
I bought a carb rebuild kit from e-bay and cleaned it and put it all back together.
Vacum? Which hoses would that be?
Thanks Dennisg
Thanks Dennisg
check your boots on the carb:yes: check your head pipe connection to the head Check your carb again ! Blowing white smoke ? check your head gasket JMO
I have checked the head and the pipe and it is tight with no leaks. The carb boots , it seems that it does not make any difference weather the boot is connected or not, just runs fast at idle with no adjustment. I assume that you are talking about the boot that goes to the airbox.
dennisg
dennisg
No I was thinkin the one that connecets the carb to the motor If you checked all that stuff then I would go back in to the carb The white smoke is puzzling to me !! Dou have any pics of the quad ?
I thought that I may have overfilled the oil, so I let some out and then ran the engine for a few minutes. Oil and white smoke still shooting out and still idling too fast. Any Ideas?
Dennisg
It is a 4 stroke. It is like it is possessed or something. The carb screws should work and the overhaul should have stopped it from smoking. It is just the same as before all of the work.
People say that it needs and overhaul and the carb needs to be rebuilt, but both of those have been done. All of the hoses and boots are in good condition. It runs too fast and the engine spews out white smoke.
Dennisg
I'm racking my brain here what little I have left. I hope you don't get tired of the question I should do a search on your quad . But here it is. Is it water cooled. How long ago was the rebuild. was it a total motor rebuild.
It is air cooled. The rebuild was two months ago, that is how long I have been trying to get it running right. The rebuild was just the top end, with new piston and rings and head with the valves reground. Keep the questions coming maybe we can figure something out.
Dennisg
Yes I used the old cylinder, but it was bored .050 over and a new piston was fitted to it. I put it all together and it still smokes like it did before the overhaul.
dennisg
I went and did an internet search all I found was 1 site saying the head gasket would cause this but it only smoked at idle. White smoke is always been moisture. I give up sorry I'm lost on this one. I hope you find the problem & if you do post it please.
Do you know if you put the rings on the piston in the right order.For the high idle Double check your throttle cable to see if their is an binding sometimes where it goes into the carb can be a little tricky. Does your throttle work smoothley. Even if your head is tight does not mean the gasket did not get damaged when you put it back togather Did you torque everything to specs and with a head you tighten head bolt alittle at a time lets say the specs say 25ft. pounds torque you would set your torque wrench at 10ft. pounds and tighten each head bolt in a cross pattern or x pattern and continue these steps till your at 25ft. pounds. Did you do it this away?
Edited by hangingon
I didn't give up yet. My advice on the head is from my auto background. And that is how you install a head on a car. I feel it should be the same for a quad other wise it is easy to damage the gasket.
  • 2 years later...
  • 9 years later...
    • By Mister907
    • By Brent Wright
    • By HeWasRidinDirty
      The one I need to replace has a 2 wire plug coming out of it. Searching eBay I see tons of them with only 1 wire . WTH???
