Loading ATV
Not really, good luck fitting 2+ quads in the bed of a truck! Why no lift the quad onto the truck? I mean, we have a trailer, but I've done it. It's not hard at all with a 470lb quad. And snowmobiles, we couldn't fit a sled in the back of our Eco F-150, so we need a trailer anyway. I dont think my quad will even fit in the back of the truck.
hes not fitting 2 quads in his truck its just one.... and yes gas is an issue to..... he wants it to be easier ya ive lifted mine in the truck to its not tht hard but i still would rather just drive it up the ramps
    • By pitts
    • By jashadams
    • By Spritee1
      not sure where to look next
    • By hardcastle
    • By McG75
