My Yamaha kodaik 450 4 wheel on commanded started to make a funny noise today it sounds like something scraping in the left front tire. on any surfaces in two wheel and fourwheel drive. the noise happens at random. i have taken the tire off and put it back on. and my hub is tight... i took the hub off and when i spin the wheel it builds up pressure and the makes the noise and then releases the pressure
I renamed the title of the thread to help others find it. What year is your quad?
I would say you have debris in your brakes or a CV joint going bad. If you put it in 4WD and turn the wheel to drive in a tight circle left and right do you hear clicking?
the quad is a 2001. yea i hear a clicking on the road when i let go of the gas. and the brake pad is shot. i will replace the pad and see if that helps. Thanks for renaming :)
    • By canamKID
      Anybody familiar with this noise from my quad? Just started.  It temporarily goes away when I attempt to shift into another gear but shifting has gotten harder too.
      20260711_150338.mp4
    • By cfherrman
    • By Shorty51
    • By flyinbrian365
      Factory service manual
    • By flyinbrian365
