2005 Arctic Cat 500cc - Will Not Start
Ok I went out on the river the other day and road around and it was wet and raining off and on my 4 wheeler was running fine and i cleaned it off that night and I went out to run the mudd off the tires today and it wont start it sounds like the starter is locked uped I tried the pull start but it wont even budge at all my motor isnt locked uped on it is it?
first thing to try would be to pull the spark plug to release the compression and try to pull start it. It is possible it could be water locked. This is an easy check and then move on from there. Add a little more info as to what kind of quad you have, what size engine and so on. The more experienced members will want more info to help you out better.
Well i was driving around with it on a trailer and i stopped at a friends and it tried to start so im sure it was the starter now the problem is it wont start it keep turning over but just wont fire off. This might sound stupid but where is the spark plug on the 4 wheeler
Its a 2005 Arctic cat 500cc 4x4
look for the wire, it should go to the top of the motor somewhere near the front. look around towards the left side under the fender towards the front. That is the left if you were sitting on the quad. even if the starter is no good you should still be able to pull start it. If you are having an issue with it not starting pulling the plug to see it you are getting spark is a good idea anyway.
Good luck.
Its not integrated with the CDI, The coil with wire is part #32 on this diagram. Here are the part numbers. Go to a local Arctic Cat dealer or order online at countrycat.net
32 3530-027 COIL, IGN $83.97
33 3430-009 SEAL, HIGH TENSION CORD $3.65
34 3430-007 CAP ASSY, SPARK PLUG $9.00
35 3430-008 SEAL SPARK PLUG $4.24
Mike
Do you know by chance where I can find just the wire and boot for the spark plug?
    • By Stoopidbot1
      I would like to take a second to say happy Father's day to all of the dad's out there... :woot:
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By Spritee1
      not sure where to look next
    • By hardcastle
