    • By p5200
      The studs in the sprocket hub are stripped out. The hub is probably walloed out also. Probably will have to have a new sprocket hub. I doubt I have the ability nor the tools needed for this job. Thanks for all suggestions/opinions!
      20240225_155255.mp4   20240225_155255.mp4 20240225_155255.mp4 20240225_155255.mp4
    • By Rich1028
      Quad Up on Two Wheels Through the Turn
    • By Steve Howard
      Ran find shut down the quad next day would start and idle when you try to accelerate it would start popping through the carb got a rebuild kit soaked it in chem clean after break down for 12 hours on slow vibrate reassembled and adjusted per manual still the same thing any help would be really appreciated thanks and happy ridding
    • By shitboxlover
      I was out riding my loncin hunter 250 yesterday when i thought i'd go through a mud hole but it did not liie that and after that it started running bad but still ran all the way home, i shut it off for the night and when i was going to start it this morning it would not fire unless i had full throttle and even then it ran bad with a lot of white smoke. Does anybody have any idea if it can be fixed or if i might as well buy a new quad
    • By quadmaniac
      I was looking online and saw some cool lifted ATVs and figured I'd start a topic. Please post if you have pics or if you find some cool lift kit ATV photos or videos online, let's keep the topic going. I just added this one in the gallery but you can just add them in this topic also.
