2007 Arctic Cat 500 4x4 dies when turning left.
By
Kawiherder, in Arctic Cat ATV Forum
Similar Tagged Content
By Alois Specht
Hi there , have a KAZUMA 500 JAGUAR the rear diff is permanently locked , how can I get it out of lock just about tried everything I think, ?? . Thank you your help is appreciated.
By mrfartsalot
i have a 2001 suzuki quadmaster 500 4x4 that the primary cvt clutch is rusted on any ideas on how to get it off i want to try to reuse it if possible.
By Paul Maple
I have a 1999 Sportsman 500, it was running fine, than started to lose power in the winter, I adjusted the idle screw and away I went, than a few weeks ago it died, I have found that i am flooding the engine, compression was at 70PSI and due to the compression release mech. i assume i am good as it compared to the same PSI on a 2000 sportsman 500 i have. i cannot start the atv unless i go full throttle and it starts an runs for about 30 sec than dies, again it is flooded. i ordered a new carb off ebay as i could get one for around $40. put that in same issue, i have checked the timing, (good), valves out of adjustment i adjusted to .006 still same issue, i have found the exhaust lobe and rocker arm to have some wear, i have ordered new ones, but am looking for any other input in this area as well. would the exhaust cam and rocker arm cause the engine to flood? i have used a bore scope and the piston liner has good cross hatching still? any input would be great.
By colin james
View File 1996-2000 Polaris Sportsman 335/500 Service Manual
This is the factory service manual for the polaris sportsman 335 & 500.
You can download the section you need or download all of the chapters for the complete manual
Submitter colin james Submitted 10/19/2018 Category Polaris ATV
By colin james
Similar Topics
By Susan Makowski-DeGraw
My quad runs, it starts up runs for about 10 minutes and then it dies if you let it sit for 10 minutes it’ll start back up ride for another 10 minutes and then die again, trying to figure out why it keeps stalling
By ENG243
Hello
I have a 1994 Kawi Bayou 400 which had been running well until it sat for about a month. I left the carb dry while it was park and the temp had dropped below 0C in this time. Pulled it out last night to go for a ride and it fired up just like it should but noticed when I started to head down the road I could hold it to the bar and it didn't seem to accelerate. Lower gears weren't as noticeable but 4th and 5th it just seemed to have no acceleration and half or full throttle made no difference. if I tried to go into 5th gear with any throttle it would stall. I turned around and just poked home very slow and it seemed to stay running but this was between 15 and 20 km/h max.
I have taken the carb apart and it appears to be clean and nothing stood out on inspection to have dirt or ice. Is there something I should dig more into?
I have checked the plug and it appears to be sooty with easily rubbed off carbon. I plan to get a new plug today and test.
compression with the throttle wide open is 175 psi.
I have opened the drain plug in the exhaust thinking there could be a mouse in the exhaust or something but no difference.
I do find the engine is tickity compared to my 2000 Honda but I am not sure if this is just me looking for issues or if it has always been this way.
If anyone has any insight I would appreciate it.
In the last 6 months I have done new oil and filter ( mystik synthetic)
new Peak RPM CDI
I have noticed the fan comes on more often with the new CDI, could this be a program thing?
Mike
By RCNY1
Hi folks, I recently purchased I believe an 02 Kodiak 4 x 4 it was stored outside, put a new battery in it still nothing kept playing around with the shifter suddenly the neutral light came on and it cranked right over no problem few days later same issue this time I can’t get the light to come on anything common I should be looking for ?
By ATVNetwork
news The KingQuad 500 and 750 Power Steering models get plastic utility rack covers.
Suzuki says the snug-fitting covers can aid load securing or be a workstation. View the full article
