89 Yamaha Big Bear 350 4x4
Im used to build threads coming from the 4x4 truck world. Im sure not as many here have older quads, but its my first, it is what it is. Im going to rock this thing :wink:
I like modifying, making the things the best they can be so Ill try to do that with my quad. I know theres only so much I can do, but my main focus is reliability. I dont care so much about power or speed. My trails around here are crawling trails anyway, so Im in 1st-3rd most of the time.
So I have an 89 Big Bear, full time 4x4, auto clutch, IFS, solid rear axle, drive-shaft, "disc" rear, drum front. Thats all I know for now, still learning, only had it two weeks or so. Ive bought a stock used air box since mine was broken and wasnt sealing anything, no filter. Got a new filter assembly, tore apart and rebuilt the carb. Oh ya got it for $900, has a winch too. About $100 into it currently.
Carb rebuid kit is on the way, few more misc parts for the carb. Its missing the little clip/housing for the throttle cable, and the baffle that goes in the float bowl. Also ordered a new ignition cylinder, I currently turn it on/off with a random key, screw driver, etc. Also the on/off switch on the left handle bar is stuck and doesnt work.
Read a later model big bears front disc setup will bolt on, or mostly bolt on. Mud and dirt dont mix with drum brakes, so Ill look further into that. It would also need a new master cylinder.
Took the muffler off, it was leaking all over. The baffle was rattling around inside the body of the muffler. So I welded it all up. One day Ill change it. Ive only seen two other "after market" muffler systems thatll hopefully work. Theyre supposed to fit later model big bears. Ill get to that one day.
Ill post pics and edit this later. Its dinner time :wink:
Edited by MrSchaeferPants
Yeah thats what Ive read. When I find a good deal on a entire front brake assembly Ill give it a try. Currently my front brakes do nothing, so some steep hills are kind of a hairy situation. My only real complaint is being a solid rear, when I traverse a hill horizontally one of the rear wheels lift off the ground, and I pucker up a bit hoping it wont tip over. But today I went everywhere my neighbors newer fully independent quad went so :laugh:
The day I brought it home
The exhaust, towards the right you can see where it came undone, I just welded it closed.
The baffle was just rattling around inside, so I pulled it to where I believed to go, and welded it in place, and closed around it. I the wife noticed a big change, and the first thing my neighbor said after my test drive was asked if I bought a new muffler :smilielol5c:
Heres after the welding. Didnt grind and clean the welds cause... I dont care :) Functional, not pretty. Believe it or not its closed/sealed. The case is welded to the baffles collar. So it just looks like theres a 1/8" gap.
You can see to the right where the frame is black with carbon. All welded closed now. My right leg/foot is much cooler now as well.
Its a temporary fix. The baffles inside are worn and broken and partially missing. One day itll see a new one.
Also replaced a valve stem/core in a tire. Thought it looked low, so I stepped on it and sure enough it was empty. I guess the tires are such a thick ply it rides w/o air in it. As soon as I looked at the valve stem I knew, filled full of silicone, as well as the outside threads. I guess someone filled a cap full of silicone and screwed it on to stop a leak. I was like really? $1.99 pack of 4 valve cores and you could of fixed the problem. So I had to remove the core, rip out all the silicone and replace it. Simple as that. Ridiculous. I guess theyre good tires? My neighbor said so anyway, Carslile Tracks Max. I know nothing about ATVs :)
And as it sits now. Ripped all that junk off the front. All together probably took 20-30lbs off the thing.
Guess Im all caught up now.
Got my new ignition cylinder in the mail yesterday, so no more turning it on/off with a screwdriver or random key that falls out while riding.
Got a tire gauge that reads low enough, someone had them things at 20psi :shock2: Hell says on the tire not to exceed 15psi to seat the bead, 5psi running. So I lowered them all to 10psi and drove around for a bit, then down to 5psi. What a huge amazing difference it made in ride comfort :) Not to mention Im sure the traction is way better, Ill find out.
Still waiting for more parts to come in. Forgot to get an oil filter in my last order of parts, so maybe Ill go down to the local dealer and find one. Who knows the last time it was changed, and I wanna put some compressed air through the oil cooler to make sure its still flowing.
Might take off the front drums and see if I can get it working, not having any kind of brakes really kinda sucks on long hills and steep areas, and always having to look for a place to stop on a trail so I can get off w/o it rolling.
Got the rest of my carb stuff in today. Had the kit for the last week, but waiting for the throttle cable retainer clip thing, and the plastic baffle plate that goes in the carb bowl. Hopefully it wont want to cut off on the steep stuff anymore.
All went well, kit came with everything. Tearing it down and reading my manual, there was a lot of things missing. Either way, my vacuum issues should be fixed. My pilot screw is set at 2.5 turns out now instead of the 4.5 it was previously, and runs well. The main needle was set at its most lean setting (kit came with a new one also), book said 3rd from the top, or the middle rung, set it there instead and it made it super rich, so put it back where it was.
Main problem still, otherwise everything is just fine- still dies as soon as I push the choke in/off position. No idea why, stumping me and pissing me off :skeptic: If it dies with the choke open, sounds to me like a lean issue. But every things fine, its clean, rebuilt, everything else is perfectly fine. Just have to run with the choke on. Starts up great, off-idle is great, part throttle is great, WOT great...etc.
Just finished taking it for a test run, once it cools down Ima check the plug to see what it looks like, but I remember previously it was just fine, tan color.
Still need to do an oil change. Just have to get a filter. I do have to put oil in here and there, its leaking around the gearbox area somewhere. Strange thing is, if the engine and gearbox share the same oil, and the dipstick can read it needs oil, but above the oil filter, theres a plug, if I take that out it gushes oil like crazy. Im confused perhaps. The trans is seperate from the 4wd part of the gearbox, using different oil, or is it all one big unit.
The "final gear" right behind the engine runs the same type of oil but is its own reservoir, drain it by pulling the bottom left bolt on the rear of the casing and fill it from the fill plug on the top as you would a differential, just until it reaches the bottom of the threads. I'm not sure what plug exactly you are referring to hut I hope that helps
As for the filter, I would recommend changing it if you don't know how long since last changed. But after that, as long as it isn't damaged you can clean it with some solvent and a soft bristled brush. Just let it dry before you reinstall it. Just change it every second or third oil change depending on the interval
  • 7 months later...
I picked up an 89 last fall. I traded a snowmoble for it.
I dont thing the front rack is original, but it works. Front lights were replaced with fog lights, I got a set of original lights off ebay for $30. Just rebuilt the carb last night, was going to put it back on today but its raining pretty good right now. I also would like to upgrade the front breaks to disk someday so I will keep an eye out here for info on that.
  • 9 months later...
MrSchaeferPants: Did you ever get your idling problem fixed.
My 89 with a rebuilt carb is missing the baffle and it surges like heck on low gear when accelerating. Also i dont get any response from the pilot screw on the bottom of carb but put it at 2 3/4 turns per manual for 4X4. Adjusting the idle speed screw gives very little response. I can idle but it is not very steady, kind of surges slightly. Like Mrschaefer I cleaned it properly and carefully rebuilt.
any suggestions?!
thanks in advance,
schmeck
my 1990 big bear runs and starts well even in our cold weather, however in order for it to keep running I have to choke it or set up the idle too fast to put it into reverse. Takes about 30 to 40 min running fast before it will idle slow enough to use the reverse. Any ideas of how to idle before such a long warm up time. I use it to push snow off my big driveway here in the north.
Edited by gopher
request help
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Spritee1
      not sure where to look next
    • By jatho
    • By hardcastle
